Dependency resolution failed
Tried to update my beta edition phone this morning, using Discover.
There are 623.2MB of updates, held up by libcanberrra=0.30+2+gc0620e4-3 Looks like this is a sound library
Anyone know a way around this?
(06-19-2021, 01:29 PM)nelstomlinson Wrote: Tried to update my beta edition phone this morning, using Discover.
Use the terminal and type:
sudo pacman -Syyu (and follow the instructions on the screen)
I did my 2G new pinephone this morning.
It's downloading stuff now, looks like that is working.  Libcanberra is getting replaced by /extra/libcanberra, and there were a couple of others like that. I said Y to all.
Still trying to figure out Manjaro, obviously.
I found the Manjaro and Arch wiki entries for pacman at
https://wiki.manjaro.org/index.php?title...n_Overview and
https://wiki.archlinux.org/title/Pacman
So now I have some reading to do.
Edited to add: that worked, and the update doesn't seem to have broken anything much, though firefox again doesn't pull up the keyboard.
(06-19-2021, 06:24 PM)RRman Wrote: So what the heck is the password I need to enter to sudo? I don't recall explicitly setting anything. And yes, I am a total newbie!
If you using Manjaro try 123456 unless you change it.
Have a look at this: https://wiki.pine64.org/wiki/PinePhone_S...anjaro_ARM
Thank you! Will check that out and give it a try.
(06-26-2021, 03:59 PM)dgiffin Wrote: Thank you! Will check that out and give it a try.
No joy :-( So what, do I need to reset something and try again? I've not done anything on the phone that I would need to keep.
Try the code you use to initially setup your phone(if you using Manjaro Plasma).
Still no joy - I've tried the only password I setup and the ones listed on that wiki page - I obviously have a crap memory :-( So how do I reset this back to the initial state and go through the whole setup routine again?
on Manjaro Plasma it is the same password you use to unlock the screen
  How to find and remove junk files from failed updates? danimations 4 3,430 10-24-2021, 11:25 PM
Last Post: danimations
  External Display Resolution Change TheBlindEarthican 3 3,908 12-08-2020, 05:21 AM
Last Post: hobbitus
