External Display Resolution Change
Device: PinePhone
Distro: Manjaro ARM (Phosh Beta 3)
External display works at "4096x2160" @ "23.37hz" on LG 49UJ6200.
Is there any other way to change the resolution then xrandr?
I am looking to TRY lower the resolution to TRY gain a better refresh rate?
Try wlrandr instead
"- is there already a tool for overclocking it desperately?"
(12-06-2020, 04:56 AM)murak Wrote: Try wlrandr instead
wlrandr not found and i can't find the package for it. I tried using autorandr but haven't seen any changes. Will see if I can force xrandr to grab the screen and change the protocal
I need to change configuration of the external display as well. For now the phone runs the default Manjaro OS, the ‘Displays’ app (Gnome’s main interface to configure various aspect of the desktop) is installed (v 3.36.3-3), but it is not available in the Settings.
  Calls/Texts and External Monitor gregb49 0 699 06-30-2023, 11:38 AM
Last Post: gregb49
  Dependency resolution failed nelstomlinson 12 20,407 12-14-2021, 10:12 AM
Last Post: jaywitness
  Lost Display Teop 0 991 11-11-2021, 10:44 AM
Last Post: Teop
  Plasma Mobile - How supposed to change screen brightness? KNERD 11 7,388 10-09-2021, 04:48 AM
Last Post: acrux
  How to close app when using dock/mouse/keyboard/ext display? alx27 0 1,259 05-27-2021, 06:09 AM
Last Post: alx27
  Display keeps dimming jojuma 5 4,786 04-27-2021, 08:26 AM
Last Post: acrux
  Display settings does not open notpod 1 2,204 12-17-2020, 09:59 AM
Last Post: notpod
  Running Docker and editing on an external monitor....awesome! retlaw 0 1,743 11-12-2020, 12:04 PM
Last Post: retlaw
