SATA SSD and case?
I'd like to attach an SSD to the Quartz64 Model-A and put them in a case.
I don't see an M.2 slot mentioned, so I guess a SATA SSD is what I need?
Does the hardware follow some existing convention, so that I might be able to find some little plastic case with the openings for Ethernet and power in the right place?
(06-15-2021, 09:34 AM)MikeInMass Wrote: I'd like to attach an SSD to the Quartz64 Model-A and put them in a case.
The listed Quartz accessories include the RockPro64 ABS enclosure. Looking at the PDF board layouts from the Wiki, both the Quartz and RockPro have very close matching board layouts. Without the actual dimensional schematic, it is hard to be sure.
Quartz64, RockPro64, PinePhone Mobian, PineBook Pro, PineTime, and all the trimmings that make FOSS fun.
the RockPro64 case should work. The SATA port is right by the USB ports on the board (the USB 3.0 port shares with it).
there's also a PCIE x4 slot which gives you some more options, though I'm not sure about things like uboot configs to boot off of either of these.
I accidentally ordered 2 quartz 8GB models so I guess I'm going to get to know it and likely help bugtest some things.
it doesn't get happy
it doesn't get sad
it just runs programs
  SATA controller problem tobs 9 3,886 03-17-2023, 01:08 PM
Last Post: CounterPillow
  Quartz64 Model A - SATA & USB3 dml-pc 0 1,249 10-13-2022, 07:43 PM
Last Post: dml-pc
  Open acrylic case olivercfc 0 1,065 07-09-2022, 04:53 PM
Last Post: olivercfc
  RockPro64 NAS case compatibility (Model A) flocke 2 2,162 06-12-2022, 10:33 AM
Last Post: flocke
  Case for the Quartz64 Model B? kuleszdl 1 1,932 06-05-2022, 02:43 PM
