Plasma Mobile "stable" currently broken
Just tested the Manjaro-ARM-plasma-mobile-pinephone-20210615.img and the result is the same - only kde logo with cursor...
So it seems that currently the best way to get it installed is use the June 9th image and update online Wink
After the update with the new Plasma everything is buggy, laggy and broken. I hope I have enough will power to proceed with the development of a framebuffer GUI probably based on https://lvgl.io/ .
(06-15-2021, 02:52 AM)mouffa Wrote: After the update with the new Plasma everything is buggy, laggy and broken.
Hmm, can't confirm here. Seems to be better with more configuration options and virtual keyboard works much better too.
Same here, in addition to it being much faster.
I still have to manually re-enable 4G though, but so far I've experienced a more stable PlasMo after the big update than before.
It still have quite a long way to go, but it's getting more and more usable.
It's even more usable than Phosh when it comes to battery life and heat, especially since currently Phosh is getting hot enough to fry an egg on it even while just lying around right after booting doing absolutely nothing at all.
母語は日本語ですが、英語も喋れます(ry
Release 202106151106 fixes it.
https://github.com/manjaro-pinephone/pla...2106151106
  what is wrong with KDE plasma beta15 RC4? Uturn 8 1,625 10-02-2023, 05:07 AM
Last Post: Uturn
  CardDAV / Nextcloud sync broken Uturn 0 697 06-15-2023, 12:41 AM
Last Post: Uturn
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,810 03-02-2023, 07:25 PM
  gnome-mobile dev Uturn 1 1,122 02-22-2023, 03:37 AM
Last Post: acrux
  Manjaro plasma-mobile Beta 13 Uturn 13 4,922 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,588 11-22-2022, 05:00 PM
Last Post: Chief
  Disabling screen timeout for plasma mobile rp3 7 7,248 09-05-2022, 03:50 PM
Last Post: christev1
  VPN on Plasma Hobgoblin 1 1,301 08-29-2022, 03:14 AM
Last Post: saddamus
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 29,497 07-28-2022, 12:40 PM
Last Post: johaennessen
  switch stable or dev release? Uturn 3 2,006 07-17-2022, 01:38 AM
Last Post: shulamy
