inner earpiece speaker replacement
I dropped my Pinephone a few days ago and have realised the inner earpiece speaker (not the main speaker at the bottom) has stopped working. I removed the mother board and reconnected everything but that hasn't changed anything.
This thread https://forum.pine64.org/showthread.php?tid=12046 has internal earpiece (and external) info:
Earpiece dimensions: 12x6x2 mm. Compatible with Xiaomi Mi2 / Mi3 / Mi4, Lenovo A536 and others.
What exactly am I looking for and can it be replaced without soldering? Apparently a fall is enough to break them.
I want to make sure I'm ordering the right part from e.g. ebay / amazon and that I can replace it.
Thanks!
I presume this would work https://www.aliexpress.com/item/32849543193.html
I think it just fits into the slot for the existing earpiece speaker and the metal contacts sticking out will work with the existing phone, no soldering required.
If anyone has a link for the speaker phone, I might get a spare just in case as shipping from China is really slow! Cheers.
And the 3mm deep speaker e.g. from here https://www.aliexpress.com/item/32774466647.html ?
I have successfully replaced the earpiece speaker. The two metal contact 'prongs' were thinner and not angled up as much so I bent them up slightly with a screwdriver.
I do get audio out of the earpiece but with the audio testing left and right speaker the volume is very low, definitely less than the original speaker. I thought the impedance / resistance would be the same and hence volume, too. It would be nice if Pine64 actually specified the exact compatible replacement part.
Anyone know what I can use with Manjaro Phosh to boost audio output beyond 100%? They don't use pulseaudio so pavucontrol doesn't work.
(07-23-2021, 11:36 PM)dcinoz Wrote: I have successfully replaced the earpiece speaker. The two metal contact 'prongs' were thinner and not angled up as much so I bent them up slightly with a screwdriver.
I'm don't know much about Pipewire (maybe try with pactl?), but have you checked if it might be a physical problem? Maybe the metal prongs don't make good contact or the speaker grill (if there is one) is dirty.
(07-24-2021, 01:48 AM)kqlnut Wrote: I'm don't know much about Pipewire (maybe try with pactl?), but have you checked if it might be a physical problem? Maybe the metal prongs don't make good contact or the speaker grill (if there is one) is dirty.
I tried with the second replacement earpiece speaker (same model) but the unfortunately result is the same. The motherboard contacts don't look evenly coloured/smooth but that is presumably where the original speaker made the contacts. Speaker contacts are fine otherwise there would be no sound. No dirt.
Upon reassembly the on/off button no longer does anything - I'll open another thread for that. Disappointed.
I set the volume to 150% using
pactl set-sink-volume 0 150%
but that didn't change anything.
  Replacement screen disconnects after back frame is screwed on robthebold 4 1,343 10-12-2023, 01:03 PM
Last Post: robthebold
Bug DESIGN ISSUE? Speaker + vibration motor broke for the 2nd time e1337 11 4,384 01-26-2023, 10:11 PM
Last Post: AnAbolitionist
  Screen Replacement Instructions erikkugel 4 3,153 09-07-2022, 11:04 PM
Last Post: RTP
  Microphone replacement SocialNetworkingWasAMistake 1 1,545 08-05-2022, 03:16 PM
Last Post: calinb
  Lost internal earpiece Veraendert 3 2,377 02-14-2022, 07:51 AM
Last Post: Veraendert
  PWM whine near earpiece in low signal phone call and loud sound sent to the other end vortex 29 26,390 01-14-2022, 11:00 AM
Last Post: eugenr
  Screen replacement Csanderson0313 4 3,230 01-10-2022, 09:26 PM
Last Post: Csanderson0313
  Replacement Loud Speaker kmsgli 18 14,503 11-01-2021, 12:25 PM
Last Post: mickclark430
  LCD panel replacement instructions mob 2 2,237 09-13-2021, 05:11 PM
Last Post: mob
  Battery replacement alternative sax1960 7 6,326 08-29-2021, 07:03 AM
Last Post: bcnaz
