Kernel rebuild resources and process for pine64-LTS
I am start using pine64-LTS board and currently installing new OS in SD card successfully. Please check below result of "uname -a" according to my board.
"Linux pine64so 5.10.34-sunxi64 #21.05.1 SMP Fri May 7 15:50"19 UTC 2021 aarch64 GNU/Linux"
Now, I want to modify or add some features through kernel. Please guide me how to get kernel source and rebuild process.
https://docs.armbian.com/Developer-Guide...eparation/
I have started compiling the kernel for pine64 board as per above suggested link by the following command.
$ ./compile.sh CLEAN_LEVEL="make,debs,oldcache,cache" NO_APT_CACHER=yes USE_TORRENT=no
I have used "NO_APT_CACHER=yes" to avoid error from proxy settings. Moreover, "USE_TORRENT=no" to avoid fetch URL failed error. However, again I have encountered an error which can be seen in the screenshot attached. I don't exactly know why this error has occurred.
Please guide me to compile it successfully.
  Uboot says bad image magic - mainline kernel lash 3 2,787 10-14-2024, 07:11 PM
Last Post: lash
  Wifi not recognized - Pine64+ / Debian Bullseye coredumpster 0 814 08-13-2024, 10:09 AM
Last Post: coredumpster
  Armbian for Pine64 LTS Mark88 1 1,146 07-26-2024, 12:48 PM
Last Post: Nepse
  Networking on A64 LTS broken on Debian with Kernel 5.9 kuleszdl 0 2,736 01-02-2021, 06:26 PM
Last Post: kuleszdl
  Building OP-TEE OS for pine64-LTS foreverska 1 4,429 12-13-2019, 03:32 PM
Last Post: foreverska
  Fedora-30 w/ kernel 5.0 maya.b 1 6,977 02-24-2019, 01:48 AM
  SoPine/Pine64 LTS: Ubuntu Mate is not booting jaganteki 0 3,409 11-20-2018, 10:49 PM
Last Post: jaganteki
  Problem setting Pine64 as a USB device martin357 2 5,582 07-02-2018, 02:08 AM
Last Post: martin357
