Can't boot from eMMC or SD card...
I broke my Arch system on my Pinephone with an incomplete update. Now I can't boot from eMMC, the loading screen roll forever.
I tried to flash Jumpdrive to SSD card. But my Pinephone won't boot to SSD card, it start Arch from eMMC anyway.
There is a solution to repair my Pinephone ? If i can chroot or something it could be nice...
Thank you !
I believe you need console cable (https://pine64.com/product/pinebook-pine...46c16e2e66) and from uboot prompt you can do recovery. I've ended up in similar situation with pbp and only tweaking with uboot got me saved.
Issue for me was that partition on emmc was corrupted, and uboot boots kernel from microsd first partition - but based on partition naming, uboot assumed that emmc root file system partition was ok (which was not). And boot ended up stuck for this reason.
So get cable and force uboot to use microsd based boot partition for kernel and rootfs.
  Pinephone boot. Richy_T 8 6,836 10-21-2025, 12:12 PM
Last Post: Richy_T
  How boot Alpine Linux realroot 4 4,534 11-02-2024, 01:00 PM
Last Post: linmob
  Tow boot MTXP 5 6,313 08-22-2024, 03:11 AM
Last Post: Pavlos1
  Pinephone won't boot. spha 13 14,780 05-15-2024, 10:31 PM
Last Post: Richy_T
  PinePhone - boot from microSD laserpyramid 9 8,815 05-03-2024, 10:09 AM
Last Post: laserpyramid
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 2,684 04-02-2024, 11:50 AM
  install iso from sd card to emmc aular 2 3,522 03-11-2024, 10:24 PM
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 4,179 01-09-2024, 07:02 PM
Last Post: britelite
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 12,679 08-28-2023, 11:38 AM
Last Post: fxc
  SD Card has wrong capacity AndyM 11 9,446 06-11-2023, 12:30 AM
Last Post: AndyM
