Can't get through "User Configuration" on new PinePhone
#21
Thanks. I wanted to make sure it works before experimenting Smile
Any opinions about running NuttX on it? although I see I need a debug cable that's not available in Europe Sad
I think NuttX for the PinePhone is not yet ready for prime time, it is still under heavy development. Also keep in mind that this is one person's project that currently seems more focused on documenting the effort of porting the operating system than on the actual ported operating system, and that even when finished, its aim is only feature phone functionality, not smartphone functionality. And you should not need any debug cable to install any kind of OS, let alone to try it out, that is what microSD cards are for. If there is not yet a NuttX image that can run from microSD or eMMC, that is a clear sign that the OS is not usable yet.
IMHO, an RTOS makes more sense on a device like the PineTime that has insufficient hardware specs for a full-fledged operating system than on the PinePhone that can run GNU/Linux just fine.
Don't get me wrong, the NuttX port is impressive (especially considering that it is done by one person) and has an educational value (due to the detailed step by step documentation of the port development). I just do not see myself running that as the primary operating system on my PinePhone any time soon.
I have the same issue, can't get trough "User Configuration"...
(05-16-2023, 03:33 AM)feketej Wrote: I have the same issue, can't get trough "User Configuration"...
see my post (#19) above.  But after a few days I followed community advice and installed a new version of the OS, since the shipped one is pretty useless.
Yes I also flashed Mobian 11, so now everything is working fine.
Manjaro is quite trashy. Sad
  PinePhone - boot from microSD laserpyramid 7 643 04-25-2024, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 371 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 250 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,810 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,859 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 627 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,414 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 513 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,747 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 7,011 12-04-2023, 02:14 AM
Last Post: Peter Gamma
