file transfer
hello,
i'm trying to figure out how to transfer music files/folders to pinephone manjaro-arm and eventually also transferring file from pinephone to p.c. (windows and linux mint).
i've had no luck figuring out kde connect with linux mint. i found a post referring to devtools,
https://forum.pine64.org/showthread.php?...+pinephone
and i downloaded the devtools from the package manager and i still don't see pinephone on windows 7. am i missing something? would acquiring a sd card make a difference?
thanks.
You can enable ssh on pinephone and use scp command on mint to transfer files over ssh connection.
You can even setup an ftp server if you want.
I usually use sshfs. Works well aside from not supporting symbolic links.
thanks for the replies! i guess i'll be boning up on ssh and scp.
  How do you install VPN so you can set up a config file, tor, signal and disk encrypt? temp0rary 5 3,950 05-30-2021, 08:14 PM
Last Post: temp0rary
  USB file transfer? SameExpert 3 4,468 05-04-2021, 09:26 AM
Last Post: SameExpert
  Which config file contains the APN specification field? Harambest 6 5,157 02-16-2021, 05:55 PM
Last Post: vkraven
  FIle Browser popup when sing Nemo/Calendar on Beta 4 nimji 5 5,230 01-28-2021, 03:29 PM
Last Post: kern707
