How to access GPS data in Mobian
Anyone know how to get the GPS information from the GPS in the PinePhone? I've tried a few programs to get the location but they all seem to go by IP address so they all basically just say the town I am in and are off by a few miles so I was hoping to get the actual information from the GPS itself but I don't know how to do that. I also tried 'whereami' and for some reason that doesn't work. I install it and it says I have the most up to date version then when I try to run `whereami` it says the package isn't installed.
You could install gpsd and run one of the clients. xgps works but is not optimized for the screen. The text based clients gpsmon and cgps will give you all the typical GPS statistical information. The NMEA output that gpsd needs is on /dev/ttyUSB1. The config file is in /etc/default/gpsd
The antenna is very weak and it will take a long time outdoors even with a clear view of the sky to get a lock. You will want to run the AGPS proof of concept script to speed up the initial lock. https://gist.github.com/alastair-dm/2632...e555fa6628
You can also talk directly to the modem via AT commands to get a location manually, It is what the AGPS script uses. https://sixfab.com/wp-content/uploads/20...l_V1.1.pdf
(05-08-2021, 08:52 PM)8bit Wrote: You could install gpsd and run one of the clients. xgps works but is not optimized for the screen. The text based clients gpsmon and cgps will give you all the typical GPS statistical information. The NMEA output that gpsd needs is on /dev/ttyUSB1. The config file is in /etc/default/gpsd
Thank you for the information! Quick question, as I don't have my PP on me right now to test, with the AGPS it says to run `AT+QGPS=1` to start the GPS, is that just ran in the command line? I don't have any real experience with working with modems in general though I do have experience with a handful of programming languages.
That would be through a serial terminal like minicom. If you run the AGPS script it turns GPS on for you so you don't need to do any manual AT commands.
If the AGPS script gives serial errors you probably need pyserial
sudo pip3 install pyserial
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 24 2,414 Yesterday, 07:42 AM
Last Post: zetabeta
  Mobian repository status henrythemouse 16 8,943 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 150 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,067 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,865 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 648 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,042 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,933 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 647 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,077 06-19-2023, 03:02 PM
Last Post: vusra
