Bluetooth keyboard with trackpad
(05-10-2021, 04:39 PM)Zebulon Walton Wrote:
(05-10-2021, 09:39 AM)wibble Wrote: If the trackpad is anything like the one on the Rii mini i8 (not bluetooth but similarly small) it will be frustrating to use - a trackpoint would be much better, or a larger touch surface on the back of the keyboard. Not sure if anyone makes one with either of those though. Being Bluetooth 3.0 it should be fine so long as they've not gone for nonstandard quirks.
I received the keyboard today and it actually works quite well. No problem connecting to the Pinephone's built-in bluetooth. Touchpad action isn't bad considering the small size. Obviously on a small keyboard like this you won't be writing any novels but it's a heck of a lot better than the on-screen keyboard for using the terminal. About the only downside I see is with bluetooth enabled on the Pinephone battery life will be shorter.
@ Zebulon Walton
@wibble
thanks for sharing this. This also one of my favorite keyboard. I've used it for years and I was always happy with it, but I have not tested yet with the Pinephone. The Ri mini 4 is eventually also worth testing. It is Bluetooth and 2.4 Ghz with it's own dongle which is included. Just to have all the options checked which are available.
I ve read it if for instance the Pinephone keyboard is attached to the PP, it is only possible to one further Bluetooth device.
Is this also the case with the Ri mini 4 connected over 2.4 GHz with it's own usb dongle? Someone write here in the forum that with the PP keyboard he could not add and usb mouse.
  keyboard case charging but not typing new2pinephone 18 5,814 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 8,781 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 433 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,195 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 457 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,247 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 524 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 620 10-21-2023, 02:55 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,025 10-20-2023, 04:11 PM
Last Post: mburns
  How to disassemble Keyboard top and replace cables? elof 2 834 10-11-2023, 09:03 AM
Last Post: elof
