First boot - no fan, no display... is it broken?
I just received my Rockpro64, I plugged the fan in, and then added the SATA adapter and some drives, plugged in the HDMI, made an armbian sdcard according to the instructions, and then plugged in the board with the power supply I ordered from Pine64.
I can hear the drives spin up, I see a little green light, but nothing else. The fan doesn't spin (is it supposed to?) I get nothing on the HDMI display.
What can I do to debug what is going on here?
Thanks!
An update to my issue.... it seems the problem was the wrong image was used to burn onto the SDcard. I had expected some kind of POST or something to suggest that things were functioning, but that is not the case. Once I burned the right image, things were able to boot.
  (real) Mainline U-boot finally works on SPI, boots SATA, throw away your SD cards NOW aleksei 0 12,998 06-21-2025, 06:21 AM
Last Post: aleksei
  enble boot after power loss/restore dkebler 18 30,726 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 228,823 09-25-2023, 12:46 AM
Last Post: ChriChri
Bug Broken boot: What am I missing? mkosarek 1 4,639 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 14,009 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 14,315 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 4,678 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 20,168 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 3,623 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 8,152 07-02-2022, 09:24 AM
Last Post: dkebler
