Pinephone64 Mobian openvpn setup
I subscribe to a VPN service that supports openvpn.  (pinephone64 CE Mobian & linux novice)
A search using "Software" 3.38.1 pointed me to GADMIN-OPENVPN-Client.  I clicked "Install", and under the "software" app, it is marked as "installed."  Its icon shows on my home screen.  Clicking the icon goes to Terminal's request that to "execute /ser/sbin/gadmin-openvpn-client requies root privileges" (using -su).  But upon entering root password, the phone returns to the home screen with no apparent action; pressing the icon returns to an open Terminal screen, asking again for the root password.  Entry of the correct root password produces "su: Authentication failure" loop.
Suggestions?
  can i install mobian on pinephone? luofeiyu 2 1,312 10-15-2022, 07:31 AM
Last Post: user641
Sad New PinePhone Mobian Weekly Image... No Boot photon 1 1,155 09-27-2022, 07:00 AM
Last Post: olyavi
  used PinePhone Mobian CE or PineTab CelynRollins 1 1,641 01-11-2022, 06:31 AM
Last Post: collierreinhold
  Help with high voltage power supply setup for electrospinning? namarang 0 1,292 08-07-2021, 11:04 AM
Last Post: namarang
  Looking to buy a used PinePhone Mobian CE or PineTab alontra 0 1,707 03-04-2021, 06:33 AM
Last Post: alontra
  Mobian Support and bug reporting cybercrypt13 2 3,184 03-02-2021, 09:26 PM
Last Post: cybercrypt13
  Where is Mobian. How do you REBOOT Mobian? K_Research 7 7,328 02-07-2021, 04:43 AM
Last Post: rocket2nfinity
  OpenVPN Server Binchonchicken 4 7,949 09-17-2017, 10:01 PM
Last Post: MarkHaysHarris777
