Minecraft Server
Did you tune the server in a special way, e.g. server.properties or spigot.yml?
Gesendet von meinem K00L mit Tapatalk
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
(04-15-2016, 12:46 PM)androsch Wrote: Did you tune the server in a special way, e.g. server.properties or spigot.yml?
Not really, I left it mostly has the spigot build built it, but i did change the mob thresholds a bit higher (so that more can spawn per chunk) and set allow-command-blocks true (its false by default)
I have built a 1.8 spigot and a 1.9.2 spigot jarfile now (i can make them available if it would please people) as i wanted to try SMP maps people had already created.
OK, did the same and some other hints from the forum, but still the 'vanilla' version seems a bit quicker than Spigot...
Thanks for the support...
@Dizzy49I I'm not sure that putting an SSD onto your Pine would have much benefit, because connecting it to the Pine would most likely use USB-2, which theoretically has a max speed of 60MB/s.
But if it's just lying around, sure, go ahead Smile
If I've helped you with something, please leave a rating for my responses.
Even you can run a moded server. 2gb can handle a small (5-10 people) server with many mods.
Heart PINE64: StackExchange Community => PINE64 Commmunity Proposal.
Proposal Status Link to Forum=> PINE64 Status Forum
Remenber to Upvote Proposed questions. And give a Follow.
For the people with Minecraft experience: did anybody try to install and run Minecraft: Pi Edition on Ubuntu or Debian?
Thanks.
I have my Pine A64 1 GB up and working with the Ubuntu image , I installed a spigot server 1.9.2 with several of the normal plugins like PEX, essentials and greifprevention and its all wonderful ! I could not get minecraft 1.9 to run smoothly on a raspberry pi2 but its flawless so far on the Pine64.
so far so good, i will test it with more users this weekend and report my results.
video of game play from client
  Mastodon instance \ Nextcloud Server fearg 1 5,630 03-31-2020, 08:18 PM
  Plex server arghne 59 161,897 07-06-2018, 10:36 AM
Last Post: Moshe.Vazan
  Turn your Pine64 into a music server with mpd JulianM 2 12,394 03-23-2017, 10:50 PM
  Plex server arghne 48 66,936 03-22-2017, 04:15 AM
Last Post: pineadmin
  Pine64 as NAS/Media Server VandaL.pr! 1 7,161 12-27-2016, 10:48 AM
Last Post: Luke
  3d printer server oldsmarracin 3 6,922 09-13-2016, 02:43 AM
Last Post: JAYJAYN
  Cannot install Plex Media Server under Arch Linux malevolent 2 6,795 09-11-2016, 12:20 PM
Last Post: ChrisLane
  Building Stratum One NTP Server lospinos 5 11,182 08-23-2016, 09:23 AM
Last Post: MarkHaysHarris777
  Starbound Server. Is the Pine64 capable? iamfallen 1 4,852 08-03-2016, 10:36 AM
  Media server montero65 3 7,428 04-28-2016, 06:02 PM
Last Post: queonda
