PXE boot - unable to login
Hi all,
  I try to boot over the network (PXE boot) and follow the tutorial https://forum.pine64.org/showthread.php?tid=6814 with the Armbian image. After some hours to understand at the end that iptables was blocking the tftp connection Angry I was able to boot but I cannot login : it is stuck when I enter the login or new password.
Do you have an idea of how to solve this issue ? root mount error ? NFS problem ?
LMM
(04-22-2021, 07:44 AM)LMM Wrote: Hi all,
LMM
I tried with both @ayufan  and @sigmaris  U-boot :
- Sigmaris U-boot stopped at booting level :
.... TFTP from server 172.21.200.1; our IP address is 172.21.200.31 Filename 'dtb-5.10.21-rockchip64/rockchip/rk3399-rockpro64.dtb'. Load address: 0x1f00000 Loading: ######         1.4 MiB/s done Bytes transferred = 75809 (12821 hex) Moving Image from 0x2080000 to 0x2200000, end=3de0000 ## Flattened Device Tree blob at 01f00000   Booting using the fdt blob at 0x1f00000
- Ayufan stopped at login level
Now it works with a not "first boot" boot files. But only with ayufan u-boot.
  (real) Mainline U-boot finally works on SPI, boots SATA, throw away your SD cards NOW aleksei 0 12,870 06-21-2025, 06:21 AM
Last Post: aleksei
  enble boot after power loss/restore dkebler 18 30,330 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 226,143 09-25-2023, 12:46 AM
Last Post: ChriChri
Bug Broken boot: What am I missing? mkosarek 1 4,541 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 13,788 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 14,125 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 4,617 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 19,918 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 3,580 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 8,004 07-02-2022, 09:24 AM
Last Post: dkebler
