Braveheart wrote blank sd to eMMC
Had this for quite a while.  I had an OS working and a sim for my provider a pay-as-you-go running on Verizon in the US.  Was told by provider it couldn't give me service.  Pinephone sat for a while then I needed the sd card for music in a very cheap Chinese mp3 player.  My car cd player just failed and decided to use the Pinephone to play to my AUX using vlc.  I ran sd card formatter on the card then tried it in the phone.  The phone still had the OS with test options.  I had never yet tried the option to write to the eMMC but thought I understood there was an OS on board in firmware that it wouldn't be a problem if the choice was wrong.  Phone died.  On button seems to do nothing.  I took out the sd card and couldn't format it.  It wouldn't get recognized so I went to my usual fix which is to format on a cheap trailcam.  Still didn't work, wouldn't get recognized on ubuntu nor Windows.  So, I went to an old compaq evo laptop having debian 3.2.51-1 i686 and a d-link hub.  Repeatedly failed but I kept swapping out sd card readers and one finally worked.  I dd if=./flasher-ubuntu-7b.img of /deb/sdb1 after dd if=./flasher-ubuntu-7b.img of=/dev/sdb didn't work.  I went to another terminal a used fdisk to see if anything was getting on the card and it was.  It showed a boot partition and another.  No more writing was getting done so I shut down the laptop and removed the sd card, put it in the PinePhone, and tried to power up but again nothing.
The phone had been getting quite hot before I wrote to the eMMC.  Now it doesn't get warm.
Where do I go from here with this?
Thanks.
soy
Quote:So I used a cheap sd card formatter and the phone just died. I wasn't expecting this, and all my files from essay writers pro were lost. The phone was rather hot and I could not format the sd card.
I tried to install JumpDrive on my SDCard. After that I booted my PinePhone.
I found a solution here: https://github.com/GloDroid/glodroid_manifest/issues/32 deploy-gpt.img to the eMMC using DD.
  install iso from sd card to emmc aular 2 2,024 03-11-2024, 10:24 PM
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 3,450 05-10-2023, 03:31 AM
Last Post: fxc
  Jumpdrive broken? eMMc broken Uturn 5 4,036 04-21-2023, 12:37 AM
Last Post: Uturn
  trouble flashing eMMC TylerBlackberry 3 2,785 04-13-2023, 05:55 AM
  This is how you flash to eMMC easily Luke 49 111,422 12-25-2022, 05:13 PM
Last Post: fxc
  emmc formatted by mistake (it no longer appears) elode 5 5,449 07-12-2022, 04:33 AM
Last Post: elode
  My Pine doesn't allow me to install to eMMC on different OS's Kimberley van Buyten 1 2,290 05-31-2022, 04:26 PM
Last Post: fxc
  no emmc after flash ragele 3 3,679 05-30-2022, 04:26 AM
Last Post: fxc
  Pinephone braveheart (+ Pinebook Pro) for sale (UK, London) chaoskampf 2 2,909 02-14-2022, 06:42 AM
Last Post: chaoskampf
  eMMC label gilwood 1 3,163 12-31-2021, 06:25 PM
Last Post: moonwalkers
