emmc formatted by mistake (it no longer appears)
During a Mobian installation test, I mistakenly formatted the EMMC with gparted.
Now with jumpdrive the emmc no longer appears.
With tow-boot, communication with my PC no longer works (the light turns blue when I press the level up button, but then the light flashes and the pinephone turns off.
On the other hand, if I flash a mobian image on the sd-card, I can still boot on it… but no more emmc :/
In a terminal, I ran the lsblk command and I get this:
mmcblk2
179:256        0   29G   0   disk
mmcblk2boot0
179:512        0   4M    1   disk
mmcblk2boot1
179:768        0   4M    1   disk
How can I retrieve the emmc?
Can anyone help me ? I'm not a computer scientist.
formatted to which file system?
ii don't think that jumpdrive care about format
 look for the emmc with gparted
ezik
(07-11-2022, 07:16 AM)shulamy Wrote: formatted to which file system?
ezik
Sorry… In fact I did not format the emmc, I deleted the partitions.
ezik
 can't you partition and format it again with gparted (or parted) from the sd card?
 ezik
i have found this
Quote:WARNING: In case eMMC isn't showing up try to charge your battery and try again. There are reports of people not being able to flash to eMMC with discharged battery.
ezik
 ezik
i have found this
The battery was fully charged...
What exactly happened:
  • in gparted, I erased the partitions of the emmc
  • gparted gave me a message that the system could not take the change into account before a reboot (i.e. the emmc partitions still appeared in Dolphin even though they no longer existed).
  • I then disconnected and reconnected the usb cable of the pinephone
…and then, no more emmc.
Since then, it has not been possible to access it.
ezik
 ezik
i have found this
Oops, I hadn't realized that we could access the emmc from the sd card… thanks Smile
So I flashed mobian to the sd card, then flashed mobian to the emmc from the sd card…and it worked!
Everything is in order. Thanks a lot for the help!
  install iso from sd card to emmc aular 2 325 03-11-2024, 10:24 PM
  pinephone no longer receiving calls or texts jyoung 3 1,805 07-16-2023, 10:05 PM
Last Post: jyoung
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 1,474 05-10-2023, 03:31 AM
Last Post: fxc
  Jumpdrive broken? eMMc broken Uturn 5 1,756 04-21-2023, 12:37 AM
Last Post: Uturn
  trouble flashing eMMC TylerBlackberry 3 1,238 04-13-2023, 05:55 AM
  No longer waking up from sleep after recent update gamerminstrel 2 1,306 01-23-2023, 08:33 AM
Last Post: gamerminstrel
  This is how you flash to eMMC easily Luke 49 81,058 12-25-2022, 05:13 PM
Last Post: fxc
  My Pine doesn't allow me to install to eMMC on different OS's Kimberley van Buyten 1 1,358 05-31-2022, 04:26 PM
Last Post: fxc
  no emmc after flash ragele 3 2,223 05-30-2022, 04:26 AM
Last Post: fxc
  eMMC label gilwood 1 2,229 12-31-2021, 06:25 PM
Last Post: moonwalkers
