PinePhone Pin/password question
It seems to me that when I try to change my password via the terminal, it also changes the PIN needed to unlock the phone, am I wrong? If so, how do you deal with a "complex" password?
Example:
PIN was, 12345 when I changed my password via passwd to "Ihatewindows" in the shell, the PIN 12345 no longer unlocks the phone.
Is there a better way to do this, or is it a limitation of m@bain?
Thanks,
Denis
(03-27-2021, 08:04 AM)dgdimick Wrote: It seems to me that when I try to change my password via the terminal, it also changes the PIN needed to unlock the phone, am I wrong? If so, how do you deal with a "complex" password?
Have you thought about using a SSH key?
(03-27-2021, 08:04 AM)dgdimick Wrote: ... is it a limitation of m@bain?
It is a limitation of phosh. The user password has to be digits only as the irksome security screen (that I wish I could get rid of) only provides a keyboard with digits!
I've found that if you hang a KB off of the phone it will allow you to connect to it before the PIN screen, however, I have not tried to us a complex password as a PIN. I reinstalled Phosh, and the latest didn't allow me to encrypt the file system.
I may have to try another disto, however, I've loaded so many applications it may not happen for a bit.
  PinePhone - boot from microSD laserpyramid 7 637 04-25-2024, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 368 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 248 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,717 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,858 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 626 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,412 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 512 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,739 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 7,008 12-04-2023, 02:14 AM
Last Post: Peter Gamma
