Interrupted during 1st boot- is it bricked?
We just got a Pine64 today and plugged it in.
During the boot and installation process, the power cord got unplugged. The phone was in the middle of extracting files and/or mounting partitions when this happened. Sad
Now the phone starts the install but after entering a PIN, it fails almost immediately with this error:
Installation Failed
Configuration Error
No partitions are defined for mount to use.
Is the Pine64 bricked? If not, how can we reset it back to bare metal and do the install again?
No, it's pretty much impossible to brick an A64 board since the sdcard has priority over the internal eMMC. So just flash a new image to an sdcard and install to eMMC, or just run an image from sdcard. More info on the wiki: https://wiki.pine64.org/wiki/PinePhone#I...structions
(03-05-2021, 10:20 AM)Thank you, xalius, that\s good to hear. I did get Mobian running on the phone from an SD card, although it seems a little pokey. Would it run faster/snappier from the eMMC? Wrote: No, it's pretty much impossible to brick an A64 board since the sdcard has priority over the internal eMMC. So just flash a new image to an sdcard and install to eMMC, or just run an image from sdcard. More info on the wiki: https://wiki.pine64.org/wiki/PinePhone#I...structions
(03-05-2021, 10:20 AM)xalius Wrote: No, it's pretty much impossible to brick an A64 board since the sdcard has priority over the internal eMMC. So just flash a new image to an sdcard and install to eMMC, or just run an image from sdcard. More info on the wiki: https://wiki.pine64.org/wiki/PinePhone#I...structions
I had the same problem while upgrading Mobian on the terminal and when was almost finish, it was iterupted. I've been trying to reflashs it with mobian (I have the mobian edition), but the phone is not recognized by the computer and Etcher. I am trying to see if Arch will work instead, but now there is a blinking reg light, a clicking sound and nothing yet. Any suggestion? I love my pinephone!
Hello NWPineFan it happen the same thing to me, but I have not being able to reboot it. can you please give move info like how did your pinephone behave after the interruption? did the phone turned back on before you reboot it from the sd? how did you reboot it from the sd? I am trying to do that but the only response I get is blinking light and black screen. I would appreciate your help, thank you.
  PinePhone - boot from microSD laserpyramid 9 832 05-03-2024, 10:09 AM
Last Post: laserpyramid
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 275 04-02-2024, 11:50 AM
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 5,336 08-28-2023, 11:38 AM
Last Post: fxc
  Pinephone won't boot. spha 12 2,876 08-20-2023, 02:44 AM
Last Post: spha
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 1,511 05-10-2023, 03:31 AM
Last Post: fxc
  UPDATED (June 2021): 17-distro multi-boot image for Pinephone (incl. 3GiB variant) megous 182 246,070 03-05-2023, 11:04 AM
Last Post: Eugo
Sad New PinePhone won't boot 9/10 times - Screen is on but stays black :( dante404 8 5,369 02-03-2023, 01:27 AM
Last Post: dante404
  no sdcard boot and manjaro update failed Gwen 3 1,446 11-27-2022, 07:56 AM
Last Post: fxc
  Tow-boot on Pinephone beta edition saddamus 10 5,507 09-11-2022, 02:43 PM
Last Post: saddamus
  Boot problem: wrong screen orientation Jetpac 6 3,845 07-18-2022, 12:47 PM
Last Post: fravoi
