Initial boot failure
I received my Mobian PinePhone today!
I powered it on, received the Mobian icon, entered a 5-digit PIN, and selected 'disable' for disk encryption.
I then received:
"Installation Failed
Configuration Error
No partitions are define
for
mount
to use.
I have not installed a microSD yet; is that the problem?
(03-02-2021, 07:08 PM)bvansteen Wrote: Hello,
I then received:
Configuration Error
for
mount
to use.
Please check out this blog: Issues and hurdles when performing the initial upgrade // Mobian's Blog (mobian-project.org)
  PinePhone - boot from microSD laserpyramid 7 583 Yesterday, 05:56 AM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 239 04-02-2024, 11:50 AM
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 5,262 08-28-2023, 11:38 AM
Last Post: fxc
  Pinephone won't boot. spha 12 2,796 08-20-2023, 02:44 AM
Last Post: spha
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 1,482 05-10-2023, 03:31 AM
Last Post: fxc
  UPDATED (June 2021): 17-distro multi-boot image for Pinephone (incl. 3GiB variant) megous 182 244,396 03-05-2023, 11:04 AM
Last Post: Eugo
Sad New PinePhone won't boot 9/10 times - Screen is on but stays black :( dante404 8 5,306 02-03-2023, 01:27 AM
Last Post: dante404
  no sdcard boot and manjaro update failed Gwen 3 1,409 11-27-2022, 07:56 AM
Last Post: fxc
  Tow-boot on Pinephone beta edition saddamus 10 5,407 09-11-2022, 02:43 PM
Last Post: saddamus
  Boot problem: wrong screen orientation Jetpac 6 3,801 07-18-2022, 12:47 PM
Last Post: fravoi
