06-10-2016, 06:08 PM
(This post was last modified: 06-10-2016, 10:03 PM by jacobscarter.)
(06-10-2016, 12:16 PM)longsleep Wrote: Headers are installed in a way out-of-tree modules can be compiled since the latest release (3.10.101-4-pine64-longsleep-51) make sure you have this and it should work. Else post full output to http://paste.ubuntu.com and share the link here.
I'm sorry I don't quite understand, I am using the Ubuntu build from this link:
https://www.stdin.xyz/downloads/people/l...es/ubuntu/
When I run uname -r I see "3.10.101-0-pine64-longsleep" but no 51 at the end. I see your 51 build at this link:
https://www.stdin.xyz/downloads/people/l...ges/linux/
But I only know how to flash the .img to a SD card, I'm not sure what I need to do with the .xz files here to get an image on the SD that will boot in the Pine64. Do I follow the same process of using the "dd" command? Perhaps the README.md at this link?:
https://www.stdin.xyz/downloads/people/l...README.txt
If you could point me in the right direction I would appreciate it.
**UPDATE**
Re-Installed this img: https://www.stdin.xyz/downloads/people/l...es/ubuntu/
I found this link:
http://forum.pine64.org/showthread.php?tid=982
In regards to the "demsg" hundreds of things are printed out and I don't know what I'm looking for.
I had to install "wireless-tools" to be able to run iwconfig but running that showed:
eth0 no wireless extensions
sit0 no wireless extensions
lo no wireless extensions
I again tried to run "make all" on the driver i got from github (see link in original post), also note first I installed "git" and "build-essential". Here is a link to the error:
http://paste.ubuntu.com/17195195/
Next i tried the github repo's README DKMS instructions to see if that would work.
On the "dkms build" build I got this missing headers error:
http://paste.ubuntu.com/17195303/
This package: "linux-headers-3.10.101-0-pine64-longsleep" does not exist so it cannot be installed.
Any advice would be appreciated. Thanks.
