Mobian phone app update 2-14
I am running mobian-pinphone-phosh-20210202.img
Today I received a system update through the phone GUI and a calling app update. Huge improvement on call quality.
I have postmarketOS edition PinePhone.
(02-14-2021, 11:19 AM)mw4jet Wrote: I am running mobian-pinphone-phosh-20210202.img
Any chance it works with bluetooth calling?
No, bluetooth does not work with calls, making a call though contacts does not work either, you have to actually input the phone number. You can text from the contacts button though.
(02-14-2021, 12:18 PM)mw4jet Wrote: No, bluetooth does not work with calls, making a call though contacts does not work either, you have to actually input the phone number.  You can text from the contacts button though.
Sorry if I don't understand correctly your comment.
Do you mean that a call from the Contact application could not be done ? I'm surprised because I can make a call using the contact list.
gnome-call seems to be broken since last update ...
can't place calls from history or cmdline using gnome-call -l
but as stated, it works from dialpad, it also works from xdg-open (and from the contacts app)
it is a minor issue (it seems to be a memory allocation failure so it should already be fixed by now)
I confirm a problem.
I can't call back from the top menu when I see a "missed call". When I've try to open the Call application a red message said "... : No voice-capable modem".
When I use Contact to make a call, all is working.
On my phone I can go to Text Message from contact page in Contact App, but to make a call, not all contacts work. (I don't want to start calling everybody in my list to know if others work). I did get one to call from the phone icon in the contact app.
My Bluetooth is acting up. I listen to audio on VLC and after 5-7 minutes it just disconnects.
issue seems to be fixed in the last gnome-calls update Smile
(02-15-2021, 05:58 PM)mw4jet Wrote: My Bluetooth is acting up. I listen to audio on VLC and after 5-7 minutes it just disconnects.
That's probably because VLC doesn't prevent the phone from going into sleep. Lollypop does, though.
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 17 2,109 Yesterday, 05:47 AM
Last Post: diederik
  Mobian repository status henrythemouse 16 8,805 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 140 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,020 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,840 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 643 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,943 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,911 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 638 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,040 06-19-2023, 03:02 PM
Last Post: vusra
