Zwave module not loaded
Hi !
I recently had to reinstall my Pine64's DietPie (raspbian mod). I use this SBC as home automation (formerly Jeedom, trying now Hass.io) with the Pine64 Zwave GPIO module.
Before this module was well recognised with Jeedom. But after reinstall (and DietPie upgrade) it isn't anymore. I first thought about a problem in HassIO's Zwave integration but it isn't. I mean /dev/ttyS2 don't link to the module :
# dmesg | grep -i tty
[    0.000000] Kernel command line: root=UUID=45e3e951-caf9-4aa6-909d-ceb24242c91e rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 consoleblank=0 loglevel=4 ubootpart=1dd8dfdc-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u
[    0.000460] printk: console [tty1] enabled
[    2.036068] printk: console [ttyS0] disabled
[    2.036157] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 38, base_baud = 1500000) is a 16550A
[    2.049344] printk: console [ttyS0] enabled
[    2.050667] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 39, base_baud = 1500000) is a 16550A
[    2.050812] serial serial0: tty port ttyS1 registered
[    6.022066] systemd[1]: Created slice system-getty.slice.
[    7.861583] usb 2-1: FTDI USB Serial Device converter now attached to ttyUSB0
[    7.866494] usb 4-1: FTDI USB Serial Device converter now attached to ttyUSB1
So it'd be a kernel module missing, isn't it ?
Here is my lsmod and my kernel version :
# uname -srv
Linux 5.10.12-sunxi64 #21.02.1 SMP Wed Feb 3 20:42:58 CET 2021
# lsmod
Module                  Size  Used by
xt_conntrack           16384  1
xt_MASQUERADE          20480  1
nf_conntrack_netlink    49152  0
xfrm_user              40960  1
xfrm_algo              16384  1 xfrm_user
nft_counter            16384  15
xt_addrtype            16384  2
nft_compat             20480  4
nft_chain_nat          16384  4
nf_nat                 40960  2 nft_chain_nat,xt_MASQUERADE
nf_conntrack          135168  4 xt_conntrack,nf_nat,nf_conntrack_netlink,xt_MASQUERADE
nf_defrag_ipv6         24576  1 nf_conntrack
nf_defrag_ipv4         16384  1 nf_conntrack
nf_tables             176128  45 nft_compat,nft_counter,nft_chain_nat
nfnetlink              16384  4 nft_compat,nf_conntrack_netlink,nf_tables
br_netfilter           28672  0
bridge                233472  1 br_netfilter
aufs                  229376  0
overlay               114688  0
sunxi_cedrus           36864  0
ftdi_sio               61440  2
snd_soc_hdmi_codec     20480  1
usbserial              45056  5 ftdi_sio
videobuf2_dma_contig    24576  1 sunxi_cedrus
axp20x_battery         16384  0
axp20x_ac_power        16384  0
v4l2_mem2mem           36864  1 sunxi_cedrus
sun4i_gpadc_iio        24576  0
axp20x_adc             20480  0
lima                   57344  0
videobuf2_memops       20480  1 videobuf2_dma_contig
videobuf2_v4l2         24576  2 sunxi_cedrus,v4l2_mem2mem
industrialio           65536  4 axp20x_battery,sun4i_gpadc_iio,axp20x_ac_power,axp20x_adc
gpu_sched              32768  1 lima
videobuf2_common       49152  3 sunxi_cedrus,videobuf2_v4l2,v4l2_mem2mem
sun4i_i2s              24576  4
dw_hdmi_cec            16384  0
dw_hdmi_i2s_audio      16384  0
videodev              241664  4 sunxi_cedrus,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem
snd_soc_simple_card    24576  0
mc                     49152  5 sunxi_cedrus,videodev,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem
sun8i_ce               28672  0
snd_soc_simple_card_utils    24576  1 snd_soc_simple_card
display_connector      20480  0
crypto_engine          20480  1 sun8i_ce
cpufreq_dt             20480  0
realtek                24576  1
pinctrl_axp209         16384  0
dwmac_sun8i            28672  0
mdio_mux               16384  1 dwmac_sun8i
i2c_mv64xxx            24576  0
Is that Marvell i2c_mv64xxx the linux kernel module for the Pine64 Zwave module ? I can't find which exact hardware it is...
I found some threads (like this one but also for others dist or SBC) about I2C, SPI, UART and hdi_uart (Bluetooth) so I've tested to add any of those kernel modules without any success...
My kernel I2C config :
# cat /proc/config.gz | gunzip | grep -i i2c
CONFIG_NFC_FDP_I2C=m
CONFIG_NFC_PN544_I2C=m
CONFIG_NFC_PN533_I2C=m
CONFIG_NFC_MICROREAD_I2C=m
CONFIG_NFC_MRVL_I2C=m
CONFIG_NFC_ST21NFCA_I2C=m
CONFIG_NFC_ST_NCI_I2C=m
CONFIG_NFC_NXP_NCI_I2C=m
CONFIG_NFC_S3FWRN5_I2C=m
CONFIG_REGMAP_I2C=y
# CONFIG_SENSORS_LIS3_I2C is not set
CONFIG_NET_DSA_MICROCHIP_KSZ9477_I2C=m
# CONFIG_NET_DSA_SMSC_LAN9303_I2C is not set
# CONFIG_MOUSE_ELAN_I2C is not set
# CONFIG_MOUSE_SYNAPTICS_I2C is not set
CONFIG_TOUCHSCREEN_AD7879_I2C=m
CONFIG_TOUCHSCREEN_AR1021_I2C=m
# CONFIG_TOUCHSCREEN_WACOM_I2C is not set
# CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set
# CONFIG_TOUCHSCREEN_SIS_I2C is not set
CONFIG_RMI4_I2C=m
CONFIG_SERIAL_SC16IS7XX_I2C=y
CONFIG_TCG_TIS_I2C_ATMEL=m
CONFIG_TCG_TIS_I2C_INFINEON=m
CONFIG_TCG_TIS_I2C_NUVOTON=m
CONFIG_TCG_TIS_ST33ZP24_I2C=m
# I2C support
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_MUX=y
# Multiplexer I2C Chip support
CONFIG_I2C_ARB_GPIO_CHALLENGE=m
CONFIG_I2C_MUX_GPIO=m
CONFIG_I2C_MUX_GPMUX=m
CONFIG_I2C_MUX_LTC4306=m
CONFIG_I2C_MUX_PCA9541=m
CONFIG_I2C_MUX_PCA954x=m
CONFIG_I2C_MUX_PINCTRL=m
CONFIG_I2C_MUX_REG=m
CONFIG_I2C_DEMUX_PINCTRL=m
CONFIG_I2C_MUX_MLXCPLD=m
# end of Multiplexer I2C Chip support
CONFIG_I2C_HELPER_AUTO=y
CONFIG_I2C_SMBUS=m
CONFIG_I2C_ALGOBIT=y
CONFIG_I2C_ALGOPCA=m
# I2C Hardware Bus support
# I2C system bus drivers (mostly embedded / system-on-chip)
CONFIG_I2C_CADENCE=m
CONFIG_I2C_CBUS_GPIO=m
CONFIG_I2C_DESIGNWARE_CORE=y
# CONFIG_I2C_DESIGNWARE_SLAVE is not set
CONFIG_I2C_DESIGNWARE_PLATFORM=y
CONFIG_I2C_EMEV2=m
CONFIG_I2C_GPIO=m
# CONFIG_I2C_GPIO_FAULT_INJECTOR is not set
CONFIG_I2C_MV64XXX=m
CONFIG_I2C_NOMADIK=m
CONFIG_I2C_OCORES=m
CONFIG_I2C_PCA_PLATFORM=m
CONFIG_I2C_RK3X=m
CONFIG_I2C_SIMTEC=m
CONFIG_I2C_XILINX=m
# External I2C/SMBus adapter drivers
CONFIG_I2C_DIOLAN_U2C=m
CONFIG_I2C_ROBOTFUZZ_OSIF=m
CONFIG_I2C_TAOS_EVM=m
CONFIG_I2C_TINY_USB=m
# Other I2C/SMBus bus drivers
# end of I2C Hardware Bus support
CONFIG_I2C_STUB=m
CONFIG_I2C_SLAVE=y
CONFIG_I2C_SLAVE_EEPROM=m
# CONFIG_I2C_SLAVE_TESTUNIT is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
# end of I2C support
# I2C GPIO expanders
# end of I2C GPIO expanders
CONFIG_BATTERY_BQ27XXX_I2C=m
CONFIG_SENSORS_LTC2947_I2C=m
CONFIG_SENSORS_OCC_P8_I2C=m
CONFIG_MFD_AXP20X_I2C=y
CONFIG_MFD_MADERA_I2C=m
# CONFIG_MFD_DA9052_I2C is not set
# CONFIG_MFD_MC13XXX_I2C is not set
# CONFIG_HTC_I2CPLD is not set
# CONFIG_MFD_TPS65912_I2C is not set
# CONFIG_MFD_ARIZONA_I2C is not set
# CONFIG_MFD_WM831X_I2C is not set
# CONFIG_MFD_WM8350_I2C is not set
CONFIG_VIDEO_V4L2_I2C=y
# IR I2C driver auto-selected by 'Autoselect ancillary drivers'
CONFIG_VIDEO_IR_I2C=m
# audio, video and radio I2C drivers auto-selected by 'Autoselect ancillary drivers'
# SPI I2C drivers auto-selected by 'Autoselect ancillary drivers'
# I2C encoder or helper chips
CONFIG_DRM_I2C_CH7006=m
CONFIG_DRM_I2C_SIL164=m
# CONFIG_DRM_I2C_NXP_TDA998X is not set
CONFIG_DRM_I2C_NXP_TDA9950=m
# end of I2C encoder or helper chips
# CONFIG_DRM_I2C_ADV7511 is not set
CONFIG_SND_SOC_I2C_AND_SPI=y
# CONFIG_SND_SOC_ADAU1761_I2C is not set
CONFIG_SND_SOC_ADAU7118_I2C=m
# CONFIG_SND_SOC_CS42L51_I2C is not set
# CONFIG_SND_SOC_CS4271_I2C is not set
# CONFIG_SND_SOC_CS42XX8_I2C is not set
# CONFIG_SND_SOC_ES8328_I2C is not set
# CONFIG_SND_SOC_MAX98373_I2C is not set
CONFIG_SND_SOC_PCM1789_I2C=m
# CONFIG_SND_SOC_PCM179X_I2C is not set
CONFIG_SND_SOC_PCM186X_I2C=m
CONFIG_SND_SOC_PCM3060_I2C=m
# CONFIG_SND_SOC_PCM3168A_I2C is not set
# CONFIG_SND_SOC_PCM512x_I2C is not set
# CONFIG_SND_SOC_SSM2602_I2C is not set
# CONFIG_SND_SOC_TLV320AIC23_I2C is not set
CONFIG_SND_SOC_TLV320AIC32X4_I2C=m
# CONFIG_SND_SOC_WM8804_I2C is not set
# I2C HID support
CONFIG_I2C_HID=m
# end of I2C HID support
# I2C RTC drivers
CONFIG_RTC_I2C_AND_SPI=y
# SPI and I2C RTC drivers
# CONFIG_MOST_I2C is not set
CONFIG_ADXL345_I2C=m
CONFIG_ADXL372_I2C=m
CONFIG_BMA400_I2C=m
CONFIG_BMC150_ACCEL_I2C=m
CONFIG_IIO_ST_ACCEL_I2C_3AXIS=m
CONFIG_KXSD9_I2C=m
CONFIG_MMA7455_I2C=m
CONFIG_BME680_I2C=m
CONFIG_IIO_MS_SENSORS_I2C=m
CONFIG_IIO_ST_SENSORS_I2C=m
CONFIG_AD5696_I2C=m
CONFIG_BMG160_I2C=m
CONFIG_FXAS21002C_I2C=m
CONFIG_MPU3050_I2C=m
CONFIG_IIO_ST_GYRO_I2C_3AXIS=m
CONFIG_HTS221_I2C=m
# CONFIG_BMI160_I2C is not set
CONFIG_FXOS8700_I2C=m
# CONFIG_INV_ICM42600_I2C is not set
# CONFIG_INV_MPU6050_I2C is not set
CONFIG_ST_UVIS25_I2C=m
CONFIG_BMC150_MAGN_I2C=m
CONFIG_IIO_ST_MAGN_I2C_3AXIS=m
CONFIG_SENSORS_HMC5843_I2C=m
CONFIG_SENSORS_RM3100_I2C=m
CONFIG_BMP280_I2C=m
# CONFIG_MPL115_I2C is not set
CONFIG_VL53L0X_I2C=m
I2C devices founded :
# ls /sys/bus/i2c/devices/
i2c-0  i2c-1
Any idea there ? Which are the *right* kernel modules ?
As a n00b, I forgot to dd an image of the SDcard before erasing it (precisely I said f***k the moment I press Return)...
  Mali Module Compiles Successfully! cztian 2 4,980 02-27-2017, 03:36 PM
Last Post: dkryder
  The sunxi transform module is very slow, how to do video rotation? jacklau 0 2,401 09-19-2016, 12:24 AM
Last Post: jacklau
