How do you shut down Mobian?
Other than prying the case off the phone and yanking out the battery how do you shut down Mobian?
(02-06-2021, 04:20 PM)K_Research Wrote: Other than prying the case off the phone and yanking out the battery how do you shut down Mobian?
Yanking the battery can corrupt the modem firmware
No idea why I can't long press the power button like every other phone.
After you login to the phone you can press on the battery icon in the top right, and the icon changes to a power button and you can power off from there.
Like @evilbunny wrote, "double" tapping the battery icon on the top left of the Phosh screen would help. Other than that, a simple shutdown -P now has always worked so far on any of those distributions.
I answered this in your other thread, but here you go again.
All Pinephones running the POSH interface like Mobian and many others, you shut down or restart by tapping on the top of the screen in the space between the time date and battery icon. When the notification/settings slider drops down you will see a power icon in the top right corner. select that and choose your option, lock screen, shut down, or restart.
Your welcome.
Took me 4 days to figure that out by the way, lol.
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 21 2,168 9 hours ago
Last Post: anonymous
  Mobian repository status henrythemouse 16 8,831 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 140 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,022 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,843 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 643 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,948 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,912 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 639 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,046 06-19-2023, 03:02 PM
Last Post: vusra
