Jami on Pinephone [ IM and VOIP ]
It is a qt6 problem - see this post
(06-08-2022, 11:48 AM)Fish Wrote: You can try the flatpak. I used it for a short time on mobian and it used to work fine.
You mean use flatpak to install the same app that's not working now under this OS? Or using flatpak to install some other SIP/VOIP softphone? If the latter, which one to install? Any recommendations?
I'm sorry for not being more clear. I meant using flatpak to install Jami. I just checked it on mobian and it works quite well.
(06-08-2022, 01:53 PM)Fish Wrote: I'm sorry for not being more clear. I meant using flatpak to install Jami. I just checked it on mobian and it works quite well.
Thanks for clarifying. I tried the flatpak version under Manjaro-ARM (Plasma) and it behaves the same as the non-flatpak one. I get only a splash screen when I try to run the app and it seems afterward at some point to just unceremoniously abort. Guess I'll have to try Mobian or some other OS to get SIP/VOIP functionality out of my PinePhone.
What is the error  if you run jami-qt from the command line?
My error is
jami-qt: symbol lookup error: jami-qt: undefined symbol: _ZN3lrc3api11PluginModel26getPluginPreferencesValuesERK7QString
Out of interest, compare the results of
pacman -Fl qt6-webengine
on your Pinephone and on your x86-64 machine. On teh Arch pinephone and Archlinux x86-64 PC they are hugely different.
PS. if you get an error run
sudo pacman -Fy
to get the pacman file lists
  Using Signal on PinePhone in mid-2023? dante404 47 13,868 05-03-2024, 02:19 AM
Last Post: dragonhospital
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 38 25,476 04-23-2024, 10:29 AM
Last Post: donchurch
  PinePhone app development WhiteHexagon 15 4,122 04-23-2024, 05:19 AM
Last Post: Jonnyc
  VoIP with SIP Mangled 8 8,657 04-07-2024, 10:19 AM
Last Post: lm2
Wink PINEPHONE not booting Touchwood 2 514 02-23-2024, 07:27 AM
Last Post: Touchwood
  Slack on PinePhone Adam Seline 5 5,478 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 24,781 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 2,110 11-23-2023, 01:06 AM
  openSUSE for Pinephone Alefnode 75 102,935 11-17-2023, 08:37 AM
Last Post: Uturn
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 1,029 11-04-2023, 07:23 PM
