Found Potential Fix For Pinephone/Verizon
While I was on the phone with Verizon tech support, I was throwing AT commands at the modem just for kicks. Through dumb luck, I managed to get calling, texting and data working. This took me from calls never going through and occasionally crashing the dialer to them being as smooth as I could hope for on experimental software. The only difference between a base pmOS phosh install and mine is that I have nano and minicom installed. Here are my steps:
List VoLTE configs:
# echo 'AT+QMBNCFG="list"' | atinout - /dev/EG25.AT -
Select proper config, in my case Verizon:
# echo 'AT+QMBNCFG="select","hVoLTE-Verizon"' | atinout - /dev/EG25.AT -
Restart modem:
# echo 'AT+QCFG="ims",1' | atinout - /dev/EG25.AT -
Restart phone.
After that, everything worked
I'm curious, does MMS (sending pics, group chats, etc) work? That's the only big road block keeping me from using it as an actual phone.
(01-26-2021, 01:59 AM)Saladhax Wrote: I'm curious, does MMS (sending pics, group chats, etc) work? That's the only big road block keeping me from using it as an actual phone.
Unfortunately, no dice on that front. Just standard SMS for now
  [Not Pinephone] Phosh Autologin LienRag 11 2,082 09-01-2023, 10:55 PM
Last Post: rocket2nfinity
  Pinephone 64 PostMarketOS edition Battery Issues, Not Hardware Issue X0X0X0X0X0 1 1,380 02-11-2023, 08:19 AM
Last Post: acid andy
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & No MMS X0X0X0X0X0 1 1,403 11-07-2022, 10:34 PM
Last Post: X0X0X0X0X0
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 1 1,171 11-06-2022, 06:41 PM
Last Post: Chief
  no screen rotation on pinephone pro with postmarketOS + phosh elode 2 2,694 07-03-2022, 09:13 AM
Last Post: a.h.littorin
  Pinephone Keyboard Utilities on postmarketOS elof 2 3,200 06-20-2022, 01:33 PM
Last Post: elof
  PinePhone, getting started totilele 1 1,494 06-15-2022, 01:56 AM
Last Post: wibble
  Bluetooth mouse paired to PinePhone POS always disconnect Peter Gamma 0 986 06-12-2022, 03:03 AM
Last Post: Peter Gamma
  gnome-firmware-updater not found (mirrors) wizardry 1 1,427 03-22-2022, 12:30 PM
Last Post: wizardry
  pinephone boots to green screen after running out of space costava 1 1,511 01-30-2022, 06:29 AM
Last Post: costava
