Can the Activity LED be enabled under Manjaro?
Hello Pine64 community,
I recently booted MrFixit's Debian image off of sd, and I noticed that the Power LED was able to blink to indicate disk activity. I have Manjaro XFCE installed on my emmc, and I'm curious to know if there's any way to enable this feature there too. Thanks.
In the kernel config : Devices --> LED Support --> LED Trigger Support
Or in userland, as root :
echo mmc0 > /sys/devices/platform/leds/leds/green\:power/trigger
you can also control the red led, the one on the side of the barrel power input.
This config is lost after reboot, you'll have to add it to a script that is run on startup to be persistent.
  Manjaro versions bad and good gilwood 0 2,556 02-12-2024, 05:03 PM
Last Post: gilwood
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 10,210 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 4,745 12-13-2023, 08:17 PM
Last Post: trillobite
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 479,893 05-12-2023, 06:09 AM
Last Post: korreckj328
  Manjaro Plasma blinking cursor jcun4128 4 5,297 05-08-2023, 11:17 AM
  PBP blank screen after updating Manjaro Franko 6 7,464 04-01-2023, 07:55 AM
Last Post: hacknix
  Manjaro - which libdrm? hacknix 0 2,010 04-01-2023, 03:21 AM
Last Post: hacknix
  Partial boot after installing Manjaro on emmc regivanx 11 11,038 02-06-2023, 09:11 AM
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 13,468 01-22-2023, 10:05 PM
Last Post: rfm83
  No boot after Manjaro flash PBcurry 14 15,198 10-03-2022, 08:33 PM
