Pinephone mainboard v1.2 documentation update?
Hi!
This thread may go out to the pine64 crew...
Maybe it would be possible to get an update on the mainboard placement documents.
PinePhone mainboard bottom placement v1.1 20191031.pdf
PinePhone mainboard top placement v1.1 20191031.pdf
There's still v1.1 available in the wiki, but it would be nice to get these documents referenced to the v1.2 boards.
Another thing to mention is, that it would be really nice to know about the exact position of the testpoints.
This might be helpful for debugging and low-level programming... or weird addons.
So far i made a list with the schematics as a reference.
v1.2 mainboard bottom:
in the middle nearby the mpu (U1, upper left):
T500 -> CPUS-UTX  (AR100 UART TX, disabled in crust, used as WL-PMU-EN)
T501 -> CPUS-URX  (AR100 UART RX, disabled in crust, used as WL-WAKE-AP)
T502 -> HDMI-CEC
T503 -> FEL  (pull low to enter FEL mode, USB-Boot)
next to ANX7688 (U1304):
T1300 -> ANX_CSDA
T1302 -> ANX_CSDL
T1502 -> GPIO0 (ANX7688
v1.2 mainboard top:
beneath J1101:
T1100 -> CTP-RST
T1101 -> CTP-INT
T1102 -> TWI0-SDA
T1103 -> TWI0-SCK
T1104 -> GPIO0-LDO (VCC-3V)
above J1200:
T1202 -> POWKEY
T1203 -> VOL-
T1204 -> VOL+
next to J1300:
T1 -> USB0-DP
T2 -> USB0-DM
T3 -> DCIN
T4 -> VBAT
in the middle nearby the modem (U1500):
T1503 -> HTXCN
T1504 -> HTXCP
T1505 -> HTX0N
T1506 -> HTX0P
T1600 -> 4K7_PD
T1601 -> USB_BOOT
The group of the HDMI signal pairs are just a guess, as we don't know the position yet.
The only reference i found in the wiki were the USB_BOOT (Modem) pins...
The craziest thing ever would be, if the board-files (e.g. gerber-data) could be shared...
Best regards,
scholbert
(01-05-2021, 07:49 AM)scholbert Wrote: This thread may go out to the pine64 crew...
(01-05-2021, 07:49 AM)scholbert Wrote: There's still v1.1 available in the wiki, but it would be nice to get these documents referenced to the v1.2 boards.
+1, please :-)
Over here, we determined the pinout of the pogo pins to be
PIN6 PIN2 PIN4
PIN1 PIN5 PIN3
Especially because these pins aren't numbered "in order" in the layout, it would have saved some work if we just had a placement document with labeled testpoints to start with.
So I would add these to the list:
T900 -> USB-5V
T901 -> PL12-POGO-INT33
T902 -> DCIN
T903 -> PE14-TWI2-SCK33
T904 -> GND
T905 -> PE15-TWI2-SDA33
  my pinephone melted norayr 6 802 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,074 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 692 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 325 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,770 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 55,623 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,374 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 963 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 8,071 08-23-2023, 03:25 AM
Last Post: Kali
  PinePhone constantly vibrating and won't take charge ImmyChan 5 5,432 07-23-2023, 03:49 PM
Last Post: kb-zealot
