Server Oriented Card
Lightbulb
Hello, I have been following this project and absolutely love what you have been doing.
I've been looking into DIY cheap server design and was comparing Pine64 against my other options as a good candidate.
The variations of the card all do a good job of catering to well-rounded software development (e.g. mobile, video, and touch).
I was wondering if you ever considered a card variation oriented towards low graphics, high cpu/memory usage?
2-4GB RAM, Ethernet, expansions, and basic video (My server box doesn't need 4K video  Angel ). Things for doing renderings, crunching calculations, running dedicated servers.
I know these generally are made to cater towards wide audiences, but it's just a thought I've been turning in my head as someone who has worked with server stacks.
Or is this a case where I should simply use the Pine64+2GB and just not utilize the extra features?
Many Thanks,
Jigen
(01-16-2016, 05:58 PM)JigenEagle Wrote: Hello, I have been following this project and absolutely love what you have been doing.
Many Thanks,
Jigen
Hi Jigen, We are observing the headless server market, and can release a new board to serve this market when we have enough inputs. For the Allwinner A64, the maximum DRAM capacity is 3GB.
(01-16-2016, 07:28 PM)tllim Wrote: Hi Jigen, We are observing the headless server market, and can release a new board to serve this market when we have enough inputs. For the Allwinner A64, the maximum DRAM capacity is 3GB.
Hearing that alone makes me very happy! And thank you for the specification. I look forward to seeing this product evolve in today's market.
For server oriented board, here is our thought and open for discussion.
- 1. Support PoE
- 2. Due to PoE circuit occupied significant board space, we will take out all circuit and ports related to HDMI, DSI-LCD Mipi, touch panel, and CSI-Camera.
- 3. Explore with Allwinner on industrial grade A64 SoC
- 4. On board eMMC flash support
- 5. Will only release 2GB SDRAM version and explore into 3GB possibility
- 1. Support PoE
  - 6. mSATA
  - 7. USB 3
  - 8. pin header for all UARTs
the Allwinner A64 SoC doesn't have build in Sata and USB 3.0 port. We can build the mSATA port from USB bus but limit to USM 2.0 bus speed.
(01-17-2016, 04:24 PM)tllim Wrote: the Allwinner A64 SoC doesn't have build in Sata and USB 3.0 port. We can build the mSATA port from USB bus but limit to USM 2.0 bus speed.
If the bridge supports UAS this could be an option. You might connect it to the USB line used to support the OTG port (I don't need OTG either), so that the bridge could make use of the full USB bandwidth exclusively.
- 1. Support PoE
  - 6. mSATA
  - 7. USB 3
Thanks on the tips and we will check on the UAS.
What about socketed emmc to support expanding the storage?
The Pine A64 board designs for microSD card booting and some eMMC pins already allocated for IO expansion purpose
You can't use emmc on the board yet. But for the next board for server use, you can use emmc port.
  Mastodon instance \ Nextcloud Server fearg 1 7,943 03-31-2020, 08:18 PM
  Plex server arghne 59 196,837 07-06-2018, 10:36 AM
Last Post: Moshe.Vazan
  Turn your Pine64 into a music server with mpd JulianM 2 15,232 03-23-2017, 10:50 PM
  Plex server arghne 48 84,205 03-22-2017, 04:15 AM
Last Post: pineadmin
  Pine64 as NAS/Media Server VandaL.pr! 1 8,718 12-27-2016, 10:48 AM
Last Post: Luke
  3d printer server oldsmarracin 3 8,990 09-13-2016, 02:43 AM
Last Post: JAYJAYN
  Cannot install Plex Media Server under Arch Linux malevolent 2 8,902 09-11-2016, 12:20 PM
Last Post: ChrisLane
  Building Stratum One NTP Server lospinos 5 14,542 08-23-2016, 09:23 AM
Last Post: MarkHaysHarris777
  Starbound Server. Is the Pine64 capable? iamfallen 1 6,229 08-03-2016, 10:36 AM
  USB Capture Card?? AUDIOTEK 3 13,511 08-02-2016, 09:27 AM
