Pinephone USB-C Docking Bar (Amazing !!)
#21
An update to me earlier post.
Occasionally I like to give the HDMI docking a try to see if anything has changed. Today it paid off, everything is working. I have to assume that my issues mentioned earlier were software issues. I'm now using debian bookworm, which is guaranteed to change many things.
I just plugged my pinephone into my Samsung tv today and it worked. I found that the 'single display' setting with the tv as the 'primary display' to be the best settings. I did find that the pinephone was not able to handle youtube video playback on a 1980x1080 screen very well. Still, it's quite amazing to have my phone apps available on a large screen.
My usb mouse worked well from the docking bar, and the onscreen keyboard (enabled under Accessibility) worked fine.
A big thank you goes out to all the devs that were able to make this work so well.
(02-16-2021, 05:56 AM)AndrewBlackmiller Wrote: I've ordered my "PinePhone KDE edition" together with the USB-C docking bar option and it simply doesn't work!
The funny thing is that it works fine plugged it into my Desktop PC.
So I ordered another docking bar (Anker PowerExpand 6-in-1) at Amazon and this one works fine now.
I use it with mouse + keyboard connected by USB and the monitor connected by HDMI.
In addition there is a PowerUSB-Plug to load the phone in parallell ( <- not perfect but usable).
Maybe this will help one or the other "PinePhone-warrior" Wink having the same problem Wink
Thanks, AndrewBlackmiller
Andrew: «Maybe this will help one or the other "PinePhone-warrior" having the same problem»
Andrew confirmed that the:
works with PinePhone KDE edition.
We can confirm that Gembird USB Typ-C
https://forum.pine64.org/showthread.php?tid=16815
does not work with PostmarketOS. And we can confirm that the Aliexpress multi adapter does not work either with PostmarketOS:
https://forum.pine64.org/showthread.php?tid=16799
There where other reports that a similar device with multi function does not work either.
The PINEPHONE USB-C Docking Bar «works with postmarketOS Community Edition and newer out-of-the-box»:
https://pine64.com/product/pinephone-usb-c-docking-bar/
The  PINEPHONE USB-C Docking Bar has a PINE 64 logo on it.
Is it a Pine64 open source developement?
We saw a very similar model from a swedish shop with no Pine64 logo on it, but only in the swedish shop and nowhere else.
  my pinephone melted norayr 6 799 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,072 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 687 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 322 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,762 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 55,582 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,373 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 960 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 8,053 08-23-2023, 03:25 AM
Last Post: Kali
  PinePhone constantly vibrating and won't take charge ImmyChan 5 5,429 07-23-2023, 03:49 PM
Last Post: kb-zealot
