Changed pw in terminal to 'asd' can't log in at phone's home screen now
I should have thought that one through! Ooops!
So my question is about factory resetting. I noticed a 'reset' button on the inside with the battery and the switches, but powering off, press and holding, doesn't seem to reset it back to original with the 123456 pw. Is there a protocol I can follow somewhere I just haven't found? Anyone know?
Are you able to ssh into it?
You can use jumpdrive to mount emmc on a PC over USB
Check out this thread, there it is explained how you can reset your password. Mount your file system (either the SD card or via Jumpdrive) and delete the password hash in the /etc/shadow file as explained (on Ubuntu Touch this file seems to be in /var/lib/extrausers).
(11-30-2020, 01:24 AM)LazyMechTech Wrote: Is there a protocol I can follow somewhere I just haven't found? Anyone know?
Your user password must be numeric.
The only way to login is using a pin code, not actually a password.
The root account can have any password you want, and very recommended to change that if you plan on using SSH on your phone.
  Looking for the "non-phone" OS wakyct 7 1,304 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 5,093 03-11-2024, 10:42 PM
Last Post: Emelia525
  Encrypting home directory coderx 1 374 02-17-2024, 10:25 PM
Last Post: aular
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 967 01-09-2024, 07:02 PM
Last Post: britelite
  Mobian PIN changed after update! Mwo87 21 17,837 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  Can the Pine Phone be serviced and updated remotely? profileyourcity 3 1,115 10-02-2023, 05:19 PM
  UBports on pine phone? robb777 16 3,823 09-01-2023, 04:26 AM
Last Post: gregb49
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 5,292 08-28-2023, 11:38 AM
Last Post: fxc
  US Cell Phone Service Providers with prices and phone numbers - UPDATED jovval 0 740 07-01-2023, 01:25 AM
Last Post: jovval
  locked out on PIN screen g40 1 658 06-07-2023, 10:20 PM
