Booting from micro SD card?
I just received the Pinephone today.
It seems like Phosh has no support for Japanese language interface, which was disappointing.
Probably I can opt in for localization, so not a big deal.
If there's no way, make your own way I'd say.
But this is not necessarily the reason to install another OS on it, the main reason is because I just prefer KDE over Gnome.
I flashed the micro SD card like this:
sudo dd if=Manjaro-ARM-plasma-mobile-dev-pinephone-201107.img of=/dev/sda1 bs=1M status=progress conv=fsync
Don't worry about the "sda1" part, my PC's drive is an NVMe type, so that one is stored on /dev/nvme0n1 instead.
I inserted the card into the phone, boot up, and the Manjaro Phosh that came pre-installed is booting up instead.
Am I missing something?
Am I supposed to hold one of the volume keys while booting?
I tried to flash using Etcher now, now booting from SD card works.
(11-24-2020, 11:48 PM)ryo Wrote: I just received the Pinephone today.
FYI, you should not dd to /dev/sda1 but to /dev/sda. the .img file is the whole flash image, not a single partition.
/dev/sda is the raw disk. /dev/sda1 is just one partition of the disk.
Wink PINEPHONE not booting Touchwood 2 457 02-23-2024, 07:27 AM
Last Post: Touchwood
  Does Ubuntu modify a Pinephone SD boot card? Peter Gamma 0 874 10-05-2023, 09:18 AM
Last Post: Peter Gamma
  External SD card not listed by Pcmanfm? Peter Gamma 1 1,550 08-22-2023, 12:22 PM
  Device memory full on multi-boot SD card Peter Gamma 4 2,753 08-27-2022, 10:03 AM
Last Post: Eugo
  Dual booting usagi 7 4,652 08-17-2022, 03:51 AM
Last Post: shulamy
  wiping u-boot off sd card shulamy 6 2,963 08-17-2022, 03:38 AM
Last Post: shulamy
  Quick and easy bootloader option for JumpDrive on external SD card? Peter Gamma 5 2,731 05-02-2022, 06:57 AM
  Writing to SD card possible with all applications? Peter Gamma 5 3,299 03-28-2022, 07:12 AM
  [Solved] How I got fsck.f2fs to get unstuck and fix not booting PP gab 1 2,310 02-08-2022, 01:35 PM
Last Post: gab
  Launching OS in the SD card from p-boot in MMC chuso 0 1,228 10-01-2021, 09:02 AM
Last Post: chuso
