Wi-Fi signal issues, randomly disconnecting
im having issues with the wifi on my pine64 LTS, im using android 6.0,
it gets a weak signal and randomly drops the connection, im unsure if its a software or hardware issue, i have swapped out both the antenna and the module with a spare and seem to be having the same issue, when it sometimes connects it says there is no internet but sometimes it still works anyway, has any 1 else had similar issues and know of a solution?
could the pine board or a tablet speaker cause interference with the signal, or does is sound like its a hardware issue?
  Connecting the RaspBee ZigBee module to 5V/GND on the Euler bus causes issues karlitos 0 1,867 04-22-2021, 03:05 AM
Last Post: karlitos
