[12.11.20 Update] Latest PinePhone CE Manjaro - Device Arrival & Initial Tests Thread
(11-10-2020, 10:48 AM)bcnaz Wrote: On the subject of "charging"  There has been some work recently on controlling the battery heat while charging.
Perhaps this piece of the safety/control software is still in an "alpha/or beta" stage, possibly causing some of the charging issues.  ?
In the past few weeks the phone does not get as hot as it did previously.
This insight is interesting, it is good to know that the power management topic is being refined.
Yes maybe this is a safety mechanism, but if that is the case, we know that currently it surely does not work correctly - since even after the charging sequence is being stopped, it is never being resumed, even after the battery state had gone from 94% down to 86%, so surely something to be looked into by the hardware / software team.
I seem to be having some aggressive problems with my pinephone that just arrived. It is freezing after ~5-10 seconds after boot, every boot. The LED is also flashing red while it is frozen, while plugged in and not plugged in. I've tried rebooting quite a few times. After booting it goes to the screen where it is asking for my wifi password, the on screen keyboard appears, but things freeze almost immediately. No response from screen touches, and the power button doesn't turn the screen on and off. I have to long press power to turn the device off, but a reboot lands me in the same spot. Should I just try flashing from a micro sd? (the slot in the case where the OS sd should have been was empty, but I do have some at my disposal)
  PinePhone - boot from microSD laserpyramid 7 575 Today, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 349 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 234 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,041 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,798 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 608 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,365 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 497 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,687 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,962 12-04-2023, 02:14 AM
Last Post: Peter Gamma
