Receiving Call During Sleep Experiment/Experience
Information
My Experience And Update To Receiving Calls During Sleep:
My Pinephone model: UBports Community Edition Hardware
Several weeks back I tested out receiving calls during deep sleep. I had no trouble receiving or making calls whatsoever (while phone was awake). During deepsleep calling from a landline, the earpiece would always ring on the caller end. No ring would show up on the Pinephone (under deep sleep). Basically, receiving calls during deepsleep did not work for me then.
Yesterday I downloaded a new image since @a-wai 's  announced "transition."
uname -a
Linux mobian 5.9-sunxi64 #3 SMP PREEMPT Tue Nov3 16:24:16 UTC 2020 aarch64 GNU/Linux
I retested calling during by putting power saving mode on sleep after 5min idle.
I waited 30 minutes and made a call to my Mobian Pinephone using a landline.
Here is what I noticed during testing Nov 5, 2020 using an AT&T network:
  1. As the first ring happened over my landline earpiece, Pinephone lit up showing wifi signal connected (no ring from Pinephone yet),
  2. Then cellular bars showed connecting, to connected
  3. After the 6th ring on my landline earpiece, the Pinephone screen went black again and the 1st ringing sound then began between 6 & 7th ring on the landline earpiece (screen still black but ringing sound came through giving me ability to pickup the call Smile).
  4. The Pinephone did ring/wakeup from sleep for the last ring! This was on my first call. I repeated this process/log twice under sleep.
To sum it up: My Pinephone itself does successfully wakeup/ring on the very last 1 or 2 rings for me. Of course you have to pick it up right away (or you can call the number back).
This is good news for me.
I'm not sure if other carriers behave differently (I am not a telecom expert). Maybe comparing/noting reports/phone behavior can lead to finding potential ideas/solutions (if others have an issue).
- RTP
"In the beginner's mind there are many possibilities, in the expert's mind there are few." -Shunryu Suzuki
[ Pinephone Original | Pinetab v1 / v2 Enjoyer ]
Linux Device Privacy / Security Playlist
(11-05-2020, 03:38 PM)RTP Wrote: ...
Maybe others have experience/report details that may in the end help lead to an idea/debug/solution (if this is still a problem for you). I'm not sure if other carriers behave differently (from the number of rings- I am not a telecom expert). Maybe we can compare reports.
Just posted in another thread I have pretty much exactly the same experience this afternoon.
Smile
  no wakeup from deep-sleep jsch 8 4,119 09-05-2022, 03:03 AM
Last Post: jsch
  Receiving SMS stopped working treebeard 11 5,572 08-12-2022, 10:31 AM
Last Post: treebeard
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 5 2,811 08-02-2022, 03:16 PM
  Chatty - XMPP receiving photos - inline display doesn't work arkadione 2 1,980 07-10-2022, 03:16 AM
Last Post: arkadione
  Pinephone incoming call / SMS notification no ringing / notification volume dcinoz 3 2,859 06-02-2022, 07:16 AM
  Vibration motor buzzes uncontrollably with call waiting Zebulon Walton 2 1,504 05-28-2022, 07:32 PM
  Not receiving SMSs biketool 1 1,347 04-17-2022, 05:11 AM
  Calls : two rings and call cut and restore. Gribouille 0 891 01-14-2022, 07:40 AM
Last Post: Gribouille
  Mobian and Deep Sleep Crust some_pinephone_user 1 1,974 11-14-2021, 07:05 AM
Last Post: some_pinephone_user
  Deep sleep shutdown the phone bitsandnumbers 19 12,947 10-22-2021, 07:04 AM
Last Post: kqlnut
