NixOS image availablee
Hi All!
Daniel Fullmer has put a link to his github repository for the pinecube on the the pinecube wiki. I flashed the provided NixOS image to SD card and booted the pinecube. It took a bit to boot, but after a short while I was able to ssh to the pinecube. Following the instructions in his repository, I was able to record from the camera to a local file first try! Well done, Daniel!
It works really well!
Hi there
I downloaded the 2020-11-07 NixOS image for a new Pinecube, and seem to have an issue recording from CSI camera.
Using the README's Additional Notes, the first `media-ctl` command is accepted, but the second `ffmpeg` produces a couple of warnings and fatal "Connection refused" messages.
The console output:
[0;nixos@nixos: ~nixos@nixos:~]$ ifconfig eth0                                  eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500                              inet 192.168.1.89  netmask 255.255.0.0  broadcast 192.168.10.255                inet6 fe80::fc4b:a0ff:fe6e:967c  prefixlen 64  scopeid 0x20<link>              ether fe:4b:a0:6e:96:7c  txqueuelen 1000  (Ethernet)                            RX packets 4265  bytes 259345 (253.2 KiB)                                      RX errors 0  dropped 0  overruns 0  frame 0                                    TX packets 240  bytes 11889 (11.6 KiB)                                          TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0                      device interrupt 39 [0;nixos@nixos: ~nixos@nixos:~]$ media-ctl --set-v4l2 '"ov5640 1-003c":0[fmt:UYV /15]'8/640x480@1/        [0;nixos@nixos: ~nixos@nixos:~]$ ffmpeg -s 640x480 -r 15 -i /dev/video0 -vcodec //192.168.1.89/live/pinecube                                                    ffmpeg version 4.3.1 Copyright (c) 2000-2020 the FFmpeg developers                built with gcc 9.3.0 (GCC)                                                      configuration: --disable-static --prefix=/nix/store/s1isxzyg45p5nmhnns8m8fk78m cmvqky-ffmpeg-4.3.1-armv7l-unknown-linux-gnueabihf --arch=armv7l --target_os=lin ux --enable-gpl --enable-version3 --enable-shared --enable-pic --enable-runtime- cpudetect --enable-hardcoded-tables --enable-pthreads --disable-w32threads --dis able-os2threads --enable-network --enable-pixelutils --enable-ffmpeg --disable-f fplay --enable-ffprobe --enable-avcodec --enable-avdevice --enable-avfilter --en able-avformat --enable-avresample --enable-avutil --enable-postproc --enable-swr esample --enable-swscale --disable-doc --enable-bzlib --enable-gnutls --enable-f ontconfig --enable-libfreetype --enable-libmp3lame --enable-iconv --enable-libth eora --enable-libssh --disable-vaapi --disable-libdrm --disable-vdpau --enable-l ibvorbis --disable-libvpx --enable-lzma --disable-opengl --disable-libmfx --disa ble-libaom --disable-libpulse --enable-libsoxr --enable-libx264 --enable-libxvid --enable-zlib --enable-libopus --enable-libspeex --enable-libx265 --enable-libd av1d --disable-debug --enable-optimizations --disable-extra-warnings --disable-s tripping --cross-prefix=armv7l-unknown-linux-gnueabihf- --enable-cross-compile    libavutil      56. 51.100 / 56. 51.100                                          libavcodec     58. 91.100 / 58. 91.100                                          libavformat    58. 45.100 / 58. 45.100                                          libavdevice    58. 10.100 / 58. 10.100                                          libavfilter     7. 85.100 /  7. 85.100                                          libavresample   4.  0.  0 /  4.  0.  0                                          libswscale      5.  7.100 /  5.  7.100                                          libswresample   3.  7.100 /  3.  7.100                                          libpostproc    55.  7.100 / 55.  7.100                                        [video4linux2,v4l2 @ 0x7c370] ioctl(VIDIOC_G_PARM): Inappropriate ioctl for devi ce        [video4linux2,v4l2 @ 0x7c370] Time per frame unknown                            [  263.240190] alloc_contig_range: [46c80, 46cf1) PFNs busy                    Input #0, video4linux2,v4l2, from '/dev/video0':                                  Duration: N/A, start: 263.387902, bitrate: N/A                                    Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p, 640x480, 15.08 tb r, 1000k tbn, 1000k tbc                                                        [tcp @ 0x81100] Connection to tcp://192.168.1.89:1935 failed: Connection refused [rtmp @ 0x80c10] Cannot open connection tcp://192.168.1.89:1935                rtmp://192.168.1.89/live/pinecube: Connection refused        [0;nixos@nixos: ~nixos@nixos:~]$
Any ideas on how to resolve this?
Thanks in advance.
Regards
(11-19-2020, 11:42 PM)sawdust Wrote: Hi there
The console output:
Thanks in advance.
Regards
Daniel's ffmpeg command tries to stream to a rtmp server. Daniel's rtmp server listens at IP 192.168.1.89.
You can either setup a rtmp server (there is a rtmp module for nginx available), or, for testing purposes, dump the video stream to a local file.
In the this case, you  replace "rtmp://192.168.1.200/live/pinecube" with "mycamera.avi" or something similar.
(11-20-2020, 10:07 AM)vfr400racer Wrote: Daniel's ffmpeg command tries to stream to a rtmp server. Daniel's rtmp server listens at IP 192.168.1.89.
Thank you for the clarification and the alternate destination.
(There's a lot I need to learn about video and "RTMP server".)
Writing to a local file was the simplest & fastest way for me to demonstrate that the camera works.
Regards
Since today is a new version with the enable speaker, try and enjoy.
https://github.com/danielfullmer/pinecub...its/master
Information OpenWrt image PineCube JuanEsf 14 36,141 05-04-2022, 05:53 PM
Last Post: JuanEsf
  Buildroot Image k0m37 3 11,427 03-14-2021, 09:48 AM
Last Post: JuanEsf
  Help to install vim (and others) in NixOS vfr400racer 0 4,372 10-26-2020, 08:56 AM
Last Post: vfr400racer
