Pinebook Pro Won't Accept Charge
Huh  My Pinebook Pro just decided to quit accepting a charge.  The wall wart is putting out 5+ VDC, but the battery doesn't charge and now is totally dead.  I do not have a USB cable and don't really want to throw good money after bad.  Is there something I can do myself to remedy this?  Can I ship it back to Pine64 for service?  Or am I SOL?
Thanks in advance for your ideas.
I see that usbC cables are starting to show up in dollar stores,,
not at all ideal for charging, but only a dollar experiment.
Do try it both ways,, ie "C" end flipped,,,, if it works, get a better one
You don't want to spend much, so I won't recommend anything else
(and don't be in a rush, give it a hour, sometimes a dead battery takes a while)
Thanks, wdt, for your reply.  I'm a total noob.  I'll look up USB C cables online just to see what you're talking about.  How does the cable hook up to the PBP?  Does it backfeed into the USB C port then?  Also, what did you mean about try it both ways?  I totally agree this is worth trying.  Much appreciated!
I bought several usb-c cables at the dollar store (one us dollar each) and they all worked fine. I also bought one at the corner gas station for $4.99 which also works fine. With usb-c it's the same as charging a phone.
Cheers!
Online will usually be a bit more money, look for the word charging, so maybe
the wires are a bit thicker,, a standard cable, "C" at one end, "A" at the other
The C end can be plugged in 2 different ways, label up or label down
Sometimes it makes a difference, sometimes not. If it is working, the red led will light
You will have to find (or buy) your most powerful charger, 2.4A is usual maximum
Obviously, for a test, OR overnight, you can use one with less amperage, try for 1A minimum
A pc, the usb3 port supplies 900 mA, usb2 gives 500mA
BTW, the pbp usbC port is NOT smart, so don't need to get fancy cable or PD/QC charger
Do try to get a cable that is thick, there are 10 wires in it after all
(10-14-2020, 09:17 PM)rempfer Wrote: Huh  My Pinebook Pro just decided to quit accepting a charge.  The wall wart is putting out 5+ VDC, but the battery doesn't charge and now is totally dead.  I do not have a USB cable and don't really want to throw good money after bad.  Is there something I can do myself to remedy this?  Can I ship it back to Pine64 for service?  Or am I SOL?
Before sending it back I'd try opening it up and unplugging the battery, leaving it 30 seconds then plugging it back in. My pinebook stopped charging a while after receipt, any time I plugged in a charger it got stuck in a loop of trying to charge then giving up and this solved it.
The USB-C cable did start charging the PBP and then, after that experiment, the AC power supply resumed charging as well.
Thank you everyone!
  Updated Pinebook Pro? tantamount 2 2,262 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 8,011 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,739 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 3,309 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 6,750 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 10,608 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 1,924 11-08-2025, 09:22 AM
Last Post: rfm83
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 8,770 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 5,169 06-28-2025, 01:25 AM
Last Post: Www
  Use SD to install new OS over pinebook debian Rudy558 10 29,756 03-09-2025, 11:17 AM
Last Post: davisthomas
