Best Gnome distro for PBP?
I was wondering if someone had the opportunity try the gnome desktop environment on other distros that could give a brief comparison to Manjaro Gnome.
It runs well enough but isn't buttery smooth all the time. If they are just as comparable as Manjaro, I will try the deepin desktop environment. Someone was able to successfully compile it another thread and had good results.
Well, I kind of had to roll my own, but the new Armbian builds work very well with GNOME desktop environment installed.
Here's a tweet showcasing what I did.
Here are the steps I took:
# Update Packages
sudo apt update
sudo apt upgrade
# Install gnome basic packages (be sure to switch to gdm3 when prompted)
sudo apt install gnome-session gdm3
# Install gnome extra packages
sudo apt install gnome-terminal gnome-control-center gnome-tweaks nautilus gedit gnome-screenshot gnome-software
# Create home directory folders
mkdir ~/Desktop ~/Downloads ~/Pictures ~/Public ~/Videos ~/Documents ~/Music ~/Templates
# Reboot, click the gear on the login screen, and choose Gnome on Xorg
Two things I am currently not able to figure out are suspend and enabling wayland.
Edit: I fixed Wayland on my own groovy build with gnome which you can download here: https://www.ironrobin.net/clover/droppy/...ro/armbian
After building my own manjaro gnome image, i am even more confident that the best gnome experience is still armbian focal. I am still having an issue getting gdm3 to start wayland, while manjaro doesnt seem to share this issue. gnome animations are way smoother on x11 armbian however. but it would be really nice to get wayland to work. this appears to be my bug: https://github.com/systemd/systemd/issues/5247
edit: build my own armbian gnome images and got wayland working out of the box! https://www.ironrobin.net/clover/droppy/...ro/armbian
  Manjaro Gnome 22.06 pamac update fail/soft-bricked-OS u974615 5 2,377 08-21-2022, 12:00 PM
Last Post: u974615
  which distro + DE are you using these days on the Pinebook Pro? halogen 26 23,280 02-23-2022, 07:55 AM
Last Post: user18130814200115
  Manjaro Gnome on Pinebook Pro Review! - My New Favourite Pinebook Pro Distro! ImmyChan 0 1,314 02-18-2022, 12:59 PM
Last Post: ImmyChan
  Sound stuttering on Manjaro gnome after latest kernel upgrade? pjsf 0 1,786 07-13-2021, 10:37 PM
Last Post: pjsf
  Recommended distro? djhnsn 2 3,241 05-14-2021, 02:03 PM
Last Post: slyecho
  Live distro GloriousCoffee 1 2,366 01-16-2021, 03:47 PM
Rainbow Armbian Groovy/Bullseye with Gnome clover 10 10,090 12-27-2020, 04:10 PM
Last Post: bus-error
Information How to make the Manjaro Gnome image update TDC_PBP 2 4,301 07-13-2020, 02:24 PM
Last Post: TDC_PBP
  Ayufan's Ubuntu Focal Gnome (20.04) mlentink 24 26,931 07-02-2020, 11:04 AM
Last Post: mlentink
Question Focal Gnome 20.04 no sound? TDC_PBP 4 5,303 06-23-2020, 02:23 PM
Last Post: Syonyk
