Wifi very slow on PBP Manjaro
My pbp  is 1 month old running default Manjaro it came with.
I am able to connect to wifi but I am only gettting 0.33, and up to 1,5 Mbits/s. On the same connection my phone get 12+ Mbits/s.
What are some tips for me to debug this? I'm not even sure how to do the proper updates.
So far I've done all the updates in the software center, in whatever the UI system is on Manjaro (separate question: what is the UI/GUI called on Manjaro), and ran pamac update && paman upgrade and this did some stuff.
I followed this post to set the wifi regulatory domain on mine (from the 1st Manjaro batch):
https://forum.pine64.org/showthread.php?tid=10502
Quote:separate question: what is the UI/GUI called on Manjaro
I'm assuming that you're asking what the default ManjaroOS Desktop Environment (DE) is, and based on your screenshot in the other post about vscode you seem to be running KDE Plasma.
You could try do downgrade the firmware,, ap6256-firmware to 2020.1-1
Sometimes this helps, actually that is what I am running
Can't help with details, there is a downgrade script that can be installed
  3 days in, slow/stuck or no boot. lgmpbp2 34 33,459 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  Problem with Wifi, Sleep, Video and PGP signature Anarethos 4 6,963 03-31-2025, 07:14 AM
Last Post: Anarethos
  Manjaro versions bad and good gilwood 0 2,923 02-12-2024, 05:03 PM
Last Post: gilwood
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 11,737 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 5,400 12-13-2023, 08:17 PM
Last Post: trillobite
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 3,115 07-13-2023, 01:50 PM
Last Post: PaulQ
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 502,617 05-12-2023, 06:09 AM
Last Post: korreckj328
  Manjaro Plasma blinking cursor jcun4128 4 5,987 05-08-2023, 11:17 AM
  PBP blank screen after updating Manjaro Franko 6 8,360 04-01-2023, 07:55 AM
Last Post: hacknix
  Manjaro - which libdrm? hacknix 0 2,368 04-01-2023, 03:21 AM
Last Post: hacknix
