just got blocked on wiki.pine64.org
Hi, I was attempting to edit a page on installing Lazarus and got this error
You do not have permission to edit this page, for the following reason:
Your IP address has been automatically blocked because it was used by another user, who was blocked by ‪Abcde‬. The reason given is:
Autoblocked because your IP address has been recently used by "Wildfit Review 15".
The reason given for Wildfit Review 15's block is "Abusing multiple accounts"
Start of block: 08:37, 6 October 2020
Expiration of block: 08:37, 7 October 2020
Intended blockee: 192.168.0.1
You may contact ‪Abcde‬ or one of the other administrators to discuss the block.
Note that you may not use the "Email this user" feature unless you have a valid email address registered in your user preferences and you have not been blocked from using it.
Your current IP address is 192.168.0.1, and the block ID is #499. Please include all above details in any queries you make.
I don't have multiple accounts, and it has logged my IP address as a local address 192.168.0.1.
I think that someone has messed up.
Well at least it wasn't 127.0.0.1. Smile
(10-06-2020, 02:59 AM)KC9UDX Wrote: Well at least it wasn't 127.0.0.1.  Smile
This is a total guess, but I'm guessing that all the traffic into the wiki goes through a reverse proxy of some kind, and therefore ALL of the users come from the same IP address (the proxy).
oops
Use a VPN for the time being?
Sent from my OnePlus 7 Pro using Tapatalk
Yep, I'm getting the same error message, and it also sees my IP address as 192.168.0.1 . VPN doesn't work, it sees all IPs as 192.168.0.1.
Can't leave a message on Abcde's talk page as we're blocked from editing.
Paging Dr. @fire219 ...
Yeah, the wiki needs to be configured properly to take the reverse proxy into account.
(10-06-2020, 03:31 PM)Avamander Wrote: Yeah, the wiki needs to be configured properly to take the reverse proxy into account.
Admins should also consider that large companies can have thousands of employees all using the same corporate proxy, and then they all have the same source IP address.
Also it is quite common for mobile connections to be NATed through common IP addresses resulting in the same thing.
There are not enough IPv4 addresses to go around and so assuming that two users on the same IP address is abuse is not a safe assumption.
I don't see them assuming that. The length of block was only 24 hours. The actual reason for blocking was spamming, and when they blocked one account, the spammer just made more from the same IP. The length of block clearly takes into account that the spammer may hop IPs, and that other people may be affected by the block.
Anyway, the block is fixed now.
Here you can see how spammers have been flinging themselves at the wiki:
https://wiki.pine64.org/index.php?title=...:BlockList
https://wiki.pine64.org/index.php?title=...g/newusers
Bots. Probably not abnormal these days.
(10-06-2020, 09:49 PM)KC9UDX Wrote: Bots.  Probably not abnormal these days.
No doubt that these are automated bots. Although happening very often, IMHO this still is abnormal Blush
  Unable to connect to Pine64 IRC channel due to certificate error? Must-Borrow 1 368 03-10-2024, 02:43 PM
Last Post: Must-Borrow
  Forum Recommendations for Pine64 support? backwoodstech2 0 366 02-04-2024, 07:12 PM
Last Post: backwoodstech2
  Im thinking of building a Pine64 cluster Theirat1991 1 551 01-12-2024, 03:31 AM
  PINE64 EU / Disappointment yoriel79 1 862 12-24-2023, 11:00 PM
Last Post: meekice
  How is it going Pine64.org? Corfromleuven 2 1,047 12-23-2023, 08:15 PM
Last Post: polinkuer12
  Registering my 'nick' on Pine64's IRC network diederik 5 1,160 11-13-2023, 07:36 PM
Last Post: ilebagels
  pine64 opensource dumbphone Phie 13 3,843 08-16-2023, 02:29 PM
Last Post: Phie
  Possible new Pine64 product - Pine Blue Ray DVD Linux tv box Omnios 5 1,507 07-24-2023, 03:21 PM
Last Post: Omnios
  My Pine64 Logo Re-Design & Thoughts About A New Logo me! 0 706 04-24-2023, 10:03 PM
Last Post: me!
  Which Pine64 single-board computer has NO on-board wireless modules? peteressive 2 1,290 03-10-2023, 03:35 PM
Last Post: peteressive
