Shipping 1.2a - HDMi No Solder ?
Hello!
I am a middle of the road hacker and I am comfortable with early release hardware and software. However I can not solder, especially anything small - I lack the dexterity (even with a microscope)
I like to play with a PinePhone. To have Mobian running with the option, using a UBC-C cable/Hub to have HDMI output when needed.
https://wiki.pine64.org/index.php?title=...rdware_Fix
Concerned if I purchase today, my lack of soldering skills is an issue. Is pinephone purchase today 1.2a+ with this issue fixed ?
Thanks,
Brendan
(10-02-2020, 05:42 AM)bmsleight Wrote: Hello!
Thanks,
Brendan
When plugging in the USB dock for HDMI output, you no longer can charge the battery due to a hardware fault of that generation.
Unless you are very skilled in fumbling around with surface mount boards, you better do not start such an adventure.
(10-02-2020, 07:21 AM)LinAdmin2 Wrote: When plugging in the USB dock for HDMI output, you no longer can charge the battery due to a hardware fault of that generation.
If I understood that correctly - maybe soldering - if I need to use HDMI for a period of time ?
God a link with more information ?
For watching HDMI you need no soldering. But if you want to have the phone charging while using the HDMI output, then you can not avoid soldering.
Do you have a source link for this? The wiki page says the 1.2a revision has the USB hardware issue fixed already - it there another problem that needs adding to that page?
There are technical details by megos and others plus
[/url][url=https://www.youtube.com/watch?v=FK2hlRQT_b0]https://www.youtube.com/watch?v=FK2hlRQT_b0
(10-07-2020, 12:23 AM)LinAdmin2 Wrote: There are technical details by megos and others plus
That vid is about a problem affecting boards up to 1.2 - those components were replaced with a different one in the 1.2a boards to fix the problem. See https://xnux.eu/devices/feature/anx7688.html for example:
Quote:USB-C CC pins are grounded when VCONN switches are off
I discovered that all the current PP variants (1.0–1.2, Braveheart and at least a part of UBports CE batch) have a major issue, that prevents CC pins from working correctly. This issue will be fixed in revision 1.2a by a component swap.
Further up the page there's mention of a problem with PD chargers (and docks that do PD) but that appears to be due to something that's not yet implemented in the driver, not a hardware issue.
Sorry but I am convinced that you are wrong Huh
I may be wrong, in which case the wiki page I linked above needs correcting, as having incorrect information out there doesn't help any of us. This is why I'm asking for sources, and providing them when I'm making an assertion.
  Issues with HDMI-out from convergence dock folgaran 1 1,203 06-16-2022, 04:35 PM
Last Post: alaraajavamma
  Can I get spare parts without disproportionate shipping fees? Anna 1 1,097 05-20-2022, 02:40 AM
Last Post: dukla2000
  Unstable HDMI out james8880 6 4,713 11-22-2021, 11:31 AM
Last Post: zltpxqhp69o2
  Replace/Solder USB-C port on Pinephone magdesign 4 3,803 07-30-2021, 09:24 PM
Last Post: bcnaz
  hdmi on dock to DVI adaptor, any success stories, failures? HDCP? tgz 0 1,539 01-09-2021, 10:24 PM
Last Post: tgz
Question No HDMI signal from new Manjaro Community Edition phone dock brianary 13 14,333 11-29-2020, 07:22 AM
Last Post: wibble
  BraveHeart UbPorts Battery drain/Solder update Vlodka 2 3,513 10-04-2020, 11:18 PM
Last Post: Vlodka
