Replace/Solder USB-C port on Pinephone
They very laggy USB-C port is a big issue for charging the phone (especially on a bicycle with dynamo or solar panel).
Is there any chance to solder a new port onto the phones pcb?
If yes, which parts would I need to buy?
https://www.ebay.com/sch/i.html?_from=R4...r&_sacat=0
Soldering I guess is somehow like this:
https://www.youtube.com/watch?v=e6TMxctCcxU
Any detailed walk-trough on how to open the phone and how to replace the port?
Cold I instead charge via pogo-pins with a 3d-printed custom case?
I can not understand the problem. If you want faster charging you should change the relevant settings in /sys filesystem to allow more current from the charger but the charger should be able to provide it, I think the phone goes to up a maximum of 3 Amperes. This has nothing to do with the USB port.
(07-30-2021, 04:38 AM)mouffa Wrote: I can not understand the problem. If you want faster charging you should change the relevant settings in /sys filesystem to allow more current from the charger but the charger should be able to provide it, I think the phone goes to up a maximum of 3 Amperes. This has nothing to do with the USB port.
The problem is that most of the USB-C cables don't make full contact and flicker (loose connection),
its a known hardware issue and it sucks big time for me, thats why I need to replace the female connector on the phone!
if you are sure that the problem is the female connector I would suggest that you give the board to a repair center and they will fix it with the appropriate solder paste, hot air gun and the right connector, I philosophically prefer doing the job myself but if I know exactly what happens I prefer to give it to the professional to have the best technical result
The Pine64 store sells the replacement usb recepticles.
Just a matter of dis-assemble and re-assemble.
Unless the original design is your problem ?
I plan on adding that to one of my future parts or accessory orders so I can have one "just in case"...
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  my pinephone melted norayr 6 718 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,025 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 638 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 260 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,651 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 54,971 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,328 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 913 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 7,895 08-23-2023, 03:25 AM
Last Post: Kali
  PinePhone constantly vibrating and won't take charge ImmyChan 5 5,350 07-23-2023, 03:49 PM
Last Post: kb-zealot
