Pinephone inner frame fused to motherboard?
Opened my phone to check connectors (re issue https://forum.pine64.org/showthread.php?tid=10882).
Freed the inner frame around the edges only to discover that it is fused to the motherboard at an area next to the battery connectors.
https://www.flickr.com/photos/185472830@...ed-public/
Coincidently(?) this area is where the usb ribbon cable passes to the SOC. Presumably this could also relate to my usb issue? The frame sits normally flat so hasn't been distorted.
Is heating recommended to help removal? Otherwise removal might be destructive. Huh
I think there's a clip there, similar to the ones around the edges. There was no glue, and no need to heat, when I took mine apart. If you want to remove the main board that's a tight fit too.
(09-29-2020, 04:47 AM)wibble Wrote: I think there's a clip there, similar to the ones around the edges. There was no glue, and no need to heat, when I took mine apart. If you want to remove the main board that's a tight fit too.
@wibble thanks for the info. I did try some tentative prying/pulling with a small screwdriver. I'll get a bit more physical and try again. Gluewise I thought some could have migrated from the original battery transport insulation tab, as the phone got quite hot the glue might have set harder then intended.
  my pinephone melted norayr 6 927 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,100 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 723 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 358 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,855 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 56,086 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,410 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 1,015 10-23-2023, 02:49 AM
Last Post: Uturn
  Replacement screen disconnects after back frame is screwed on robthebold 4 1,426 10-12-2023, 01:03 PM
Last Post: robthebold
  PinePhone Keyboard KJ6OHG 11 8,170 08-23-2023, 03:25 AM
Last Post: Kali
