No Connection to Carrier from Pinephone 3G Model
OK I reflashed the Modem Firmware:
It was successfull
[034.898]: THE TOTAL DOWNLOAD TIME IS 29.555 s
[034.898]: Upgrade module successfully.
But the problem is still the same:
No connection to carrier!!!
Okt 23 09:55:44 alarm kernel: modem-power serial1-0: ===================================================
Okt 23 09:55:44 alarm kernel: modem-power serial1-0: Version: RPMR07A03_1:37500: Dec 2 2019
Okt 23 09:55:44 alarm kernel: modem-power serial1-0: Version: TZR07A03: Dec 2 2019
Okt 23 09:55:44 alarm kernel: modem-power serial1-0: Version: SBLR07EG25G01_1:37500: May 30 2
Okt 23 09:55:44 alarm kernel: modem-power serial1-0: Build Date: 2020-06-13,09:14
Okt 23 09:55:44 alarm kernel: modem-power serial1-0: Custom Name : STD
Okt 23 09:55:44 alarm kernel: modem-power serial1-0: Branch Name: 9x07_R07_NEW
Okt 23 09:55:44 alarm kernel: modem-power serial1-0: Project Rev : EG25GGBR07A08M2G_01.002.07
Okt 23 09:55:44 alarm kernel: modem-power serial1-0: Project Name: EG25G
Okt 23 09:55:43 alarm kernel: modem-power serial1-0: ===================================================
I only get this:
Okt 23 09:55:52 alarm ModemManager[3780]: <warn> [modem0] couldn't load supported assistance data types: LOC service: general failure
Okt 23 09:55:51 alarm ModemManager[3780]: <warn> [modem0] couldn't load list of own numbers: Couldn't get MSISDN: QMI protocol error (16): 'NotProvisioned'
Okt 23 09:55:51 alarm ModemManager[3780]: <warn> [modem0/sim0] couldn't load list of emergency numbers: uninitialized emergency numbers list
Okt 23 09:55:51 alarm ModemManager[3780]: <warn> [modem0/sim0] couldn't load operator name: Couldn't get home network: QMI protocol error (16): 'NotProvisioned'
Okt 23 09:55:51 alarm ModemManager[3780]: <warn> [modem0/sim0] couldn't load operator identifier: Couldn't get home network: QMI protocol error (16): 'NotProvisioned'
And if I search for the network in phosh manualy this:
Okt 23 09:57:28 alarm gnome-control-c[3945]: Error: scanning networks failed: Zeitüberschreitung wurde erreicht
Okt 23 09:57:42 alarm ModemManager[3780]: <warn> [modem0] couldn't load operator name: Current operator description is still unknown
Okt 23 09:57:42 alarm ModemManager[3780]: <warn> [modem0] couldn't load operator code: Current operator MCC/MNC is still unknown
From my side it's not an Error with the firmware.
Currently I tried 3 different SIM Cards,
and wrote the whole firmware to the modem.
I think the Modem is broken somehow.
(10-23-2020, 04:24 AM)merlin Wrote: OK I reflashed the Modem Firmware:
It was successfull
I only get this:
This may seem simple, but have you checked the connections to the antenna and looked for anything on the circuit board that may not be right - i.e. loose/overtight screws, a spec of solder somewhere or not where it should be? Something amiss with the sim card tray? It seems the modem is functional but just isn't connecting.
It was successfull
I only get this:
I didn't open the device until now.
I tested around with AT commands (first time trying this).
I wrote a library in python to have a simple AT Commandline.
The sim is correctly connected, I could read out the  ID of the SIM:
--> AT+QCCID
<-- +QCCID: 89120000.....
Reception power is really low:
--> AT$QCSQ
<-- $QCSQ :-91,-2,0,0,-93
Tomorrow I'ill take a screwdriver and have a look at the antenna.
Yes, that simply was it.
The connector was lying next to the plug Huh
So easy could a problem be solved.
(10-24-2020, 09:53 AM)merlin Wrote: Yes, that simply was it.
WOW this is good to know!!
Glad to see you found and fixed the problem !
This is something that could be useful to other users.
Thanks to your persistence  !
Hi @merlin
I have the same problem as you, I opnened the PinePhone but I could not distinguish if the wire is connectes or not... Do you have a photo of the part of the phone I have to look at?
Thanks in advance!
  my pinephone melted norayr 6 793 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,072 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  Supported Carrier and Modem Bands NachoMomma 4 1,559 03-23-2024, 02:00 PM
  Microphone on Hardware Model 1.2 is Unusably Noisy In Some Circomstances ASmartSuitedSimpleton 4 3,880 03-23-2024, 10:55 AM
Last Post: Ferriah
  various tricks to open the pinephone shengchieh 2 687 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 322 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,761 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 55,560 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,373 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 960 10-23-2023, 02:49 AM
Last Post: Uturn
