Debian memory fragment
hi,
I'm using Debian with kernel tree 101 (not 65) and have the 2GB board.
The server is used with pools coin mining software (already used onto Raspberry Pi2 without problem with Raspian).
I get kernel messages of out of memory due to fragmentation (some python script of the pool use lot of contiguos memory).
May 25 20:16:27 localhost kernel: [187398.049922] python2.7: page allocation failure: order:1, mode:0x200020
May 25 20:16:27 localhost kernel: [187398.057186] CPU: 1 PID: 5604 Comm: python2.7 Tainted: G           O 3.10.101-0-pine64-l
ongsleep #39
May 25 20:16:27 localhost kernel: [187398.069955] [<ffffffc000088388>] dump_backtrace+0x0/0x118
May 25 20:16:27 localhost kernel: [187398.075965] [<ffffffc0000884c4>] show_stack+0x24/0x30
May 25 20:16:27 localhost kernel: [187398.081592] [<ffffffc0006be948>] dump_stack+0x20/0x28
May 25 20:16:27 localhost kernel: [187398.087213] [<ffffffc00015fb58>] warn_alloc_failed+0x118/0x130
May 25 20:16:27 localhost kernel: [187398.093682] [<ffffffc000162d38>] __alloc_pages_nodemask+0x6b8/0x834
May 25 20:16:27 localhost kernel: [187398.100629] [<ffffffc00019deb4>] cache_alloc_refill+0x370/0x6ac
May 25 20:16:27 localhost kernel: [187398.107193] [<ffffffc00019e4a0>] kmem_cache_alloc+0x9c/0x200
May 25 20:16:27 localhost kernel: [187398.113472] [<ffffffc0005bc584>] sk_prot_alloc+0x3c/0x10c
May 25 20:16:27 localhost kernel: [187398.119465] [<ffffffc0005be94c>] sk_clone_lock+0x34/0x290
May 25 20:16:27 localhost kernel: [187398.125460] [<ffffffc000607e58>] inet_csk_clone_lock+0x30/0xb0
May 25 20:16:27 localhost kernel: [187398.131930] [<ffffffc00061e588>] tcp_create_openreq_child+0x38/0x34c
May 25 20:16:27 localhost kernel: [187398.138970] [<ffffffc00061b64c>] tcp_v4_syn_recv_sock+0x4c/0x234
May 25 20:16:27 localhost kernel: [187398.145628] [<ffffffc00061eca8>] tcp_check_req+0x304/0x4c0
May 25 20:16:27 localhost kernel: [187398.151717] [<ffffffc00061b9ac>] tcp_v4_do_rcv+0x178/0x330
May 25 20:16:27 localhost kernel: [187398.157803] [<ffffffc00061de18>] tcp_v4_rcv+0x4c0/0x6ec
Message from syslogd@localhost at May 25 20:26:04 ...
kernel:[187965.808278] Call trace:
May 25 20:16:27 localhost kernel: [187398.163607] [<ffffffc0005fcbb8>] ip_local_deliver_finish+0x13c/0x240
May 25 20:16:27 localhost kernel: [187398.170642] [<ffffffc0005fd140>] ip_local_deliver+0x88/0x9c
May 25 20:16:27 localhost kernel: [187398.176826] [<ffffffc0005fcfa0>] ip_rcv_finish+0x2e4/0x2f4
May 25 20:16:27 localhost kernel: [187398.182914] [<ffffffc0005fd3ec>] ip_rcv+0x298/0x2dc
May 25 20:16:27 localhost kernel: [187398.188338] [<ffffffc0005cf82c>] __netif_receive_skb_core+0x650/0x6d0
May 25 20:16:27 localhost kernel: [187398.195472] [<ffffffc0005cf8d4>] __netif_receive_skb+0x28/0x84
May 25 20:16:27 localhost kernel: [187398.201942] [<ffffffc0005d089c>] process_backlog+0xbc/0x194
May 25 20:16:27 localhost kernel: [187398.208124] [<ffffffc0005d06c4>] net_rx_action+0xe0/0x1fc
May 25 20:16:27 localhost kernel: [187398.214122] [<ffffffc0000b5ff8>] __do_softirq+0x160/0x2d8
May 25 20:16:27 localhost kernel: [187398.220118] [<ffffffc0000b625c>] do_softirq+0x54/0x64
May 25 20:16:27 localhost kernel: [187398.225733] [<ffffffc0000b62fc>] local_bh_enable_ip+0x90/0xbc
May 25 20:16:27 localhost kernel: [187398.232105] [<ffffffc0006c3890>] _raw_spin_unlock_bh+0x44/0x50
May 25 20:16:27 localhost kernel: [187398.238579] [<ffffffc0005bdc78>] release_sock+0x104/0x130
May 25 20:16:27 localhost kernel: [187398.244576] [<ffffffc00062e478>] inet_stream_connect+0x54/0x68
May 25 20:16:27 localhost kernel: [187398.251043] [<ffffffc0005bab78>] SyS_connect+0x8c/0xb4
May 25 20:16:27 localhost kernel: [187398.256748] Mem-Info:
May 25 20:16:27 localhost kernel: [187398.259321] DMA per-cpu:
May 25 20:16:27 localhost kernel: [187398.262178] CPU    0: hi:  186, btch:  31 usd:  28
May 25 20:16:27 localhost kernel: [187398.267506] CPU    1: hi:  186, btch:  31 usd:   0
May 25 20:16:27 localhost kernel: [187398.272835] CPU    2: hi:  186, btch:  31 usd:   0
May 25 20:16:27 localhost kernel: [187398.278161] CPU    3: hi:  186, btch:  31 usd:  62
May 25 20:16:27 localhost kernel: [187398.283495] active_anon:202579 inactive_anon:112366 isolated_anon:23
May 25 20:16:27 localhost kernel: [187398.283495]  active_file:76997 inactive_file:88954 isolated_file:0
May 25 20:16:27 localhost kernel: [187398.283495]  unevictable:27 dirty:265 writeback:0 unstable:0
May 25 20:16:27 localhost kernel: [187398.283495]  free:6228 slab_reclaimable:5357 slab_unreclaimable:4630
May 25 20:16:27 localhost kernel: [187398.283495]  mapped:12866 shmem:19578 pagetables:1549 bounce:0
May 25 20:16:27 localhost kernel: [187398.283495]  free_cma:721
May 25 20:16:27 localhost kernel: [187398.320086] DMA free:23920kB min:5612kB low:7012kB high:8416kB active_anon:810316kB inactive_anon:449464kB active_file:307988kB inactive_file:356808kB unevictable:108kB isolated(anon):92kB isolated(file):0kB present:2080768kB managed:1969892kB mlocked:108kB dirty:1060kB writeback:0kB mapped:51464kB shmem:78312kB slab_reclaimable:21428kB slab_unreclaimable:18520kB kernel_stack:3472kB pagetables:6196kB unstable:0kB bounce:0kB free_cma:2884kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
May 25 20:16:27 localhost kernel: [187398.368043] lowmem_reserve[]: 0 0 0
May 25 20:16:27 localhost kernel: [187398.371956] DMA: 4021*4kB (UEMC) 395*8kB (UEMC) 52*16kB (UMRC) 28*32kB (MR) 10*64kB (MR) 3*128kB (M) 1*256kB (M) 1*512kB (R) 1*1024kB (R) 0*2048kB 0*4096kB = 23788kB
May 25 20:16:27 localhost kernel: [187398.388272] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
May 25 20:16:27 localhost kernel: [187398.397584] 196748 total pagecache pages
May 25 20:16:27 localhost kernel: [187398.401963] 10852 pages in swap cache
May 25 20:16:27 localhost kernel: [187398.406055] Swap cache stats: add 302607, delete 291755, find 506797/524929
May 25 20:16:27 localhost kernel: [187398.413750] Free swap  = 328416kB
May 25 20:16:27 localhost kernel: [187398.417459] Total swap = 524284kB
May 25 20:16:27 localhost kernel: [187398.421172] SLAB: Unable to allocate memory on node 0 (gfp=0x20)
May 25 20:16:27 localhost kernel: [187398.427825]   cache: TCP, object size: 1728, order: 1
May 25 20:16:27 localhost kernel: [187398.433438]   node 0: slabs: 11/11, objs: 44/44, free: 0
here  te actual memory state (I have even 512MB swap area)
top - 20:30:14 up 2 days,  5:07,  1 user,  load average: 2.14, 2.36, 2.47
Tasks: 143 total,   1 running, 142 sleeping,   0 stopped,   0 zombie
%Cpu(s): 12.2 us,  5.6 sy, 30.0 ni, 31.6 id, 20.6 wa,  0.0 hi,  0.0 si,  0.0 st
KiB Mem:   2036960 total,  2013580 used,    23380 free,     2652 buffers
KiB Swap:   524284 total,   195868 used,   328416 free.   727200 cached Mem
here the fragmentation:
root@pine64pro:# cat /proc/buddyinfo
Node 0, zone      DMA   1420    162     62     11      5      1      0      1      1      0      0
Any Idea about something to do to prevent those errors?
Mhm i do not see why this error would be specific to the Pine64. It might be related to aarch64 though. Could you try to pretty print the output of /proc/buddyinfo (eg. with a script like the one in http://andorian.blogspot.de/2014/03/maki...yinfo.html). Especially compare the output directly after boot and when your software is running and how much it tries to allocate.
thanks, I will test after I can make a reboot (at least in the weekend).
I did not know if it is related to aarch64, but in Raspberry Pi2 with 32bit and 1GB or RAM (with a swap of 256Mb if I rememeber good) I never get such message in 6 months of 24/24 server running.
The unique difference in swap memory  is that Raspian installation probably had create a  swap dedicated partition, while in Pine64 I have a 512MB file used as swap area created by me.
1 minute after the boot:
root@pine64pro:/home/debian# python /root/fragment.py
2016-05-28 14:27:55,939 - main - INFO - Starting....
2016-05-28 14:27:55,939 - main - INFO - Parsed options: {'size': None}
<logging.Logger object at 0x7fa7a844d0>
2016-05-28 14:27:55,940 - main - DEBUG - Parsing line: Node 0, zone      DMA     52     13      9      6      3      1      2      5      5      3    101
2016-05-28 14:27:55,943 - main - DEBUG - Parsed line: {'numa_node': '0', 'zone': 'DMA', 'nr_free': '52     13      9      6      3      1      2      5      5      3    101'}
2016-05-28 14:27:55,944 - main - INFO - defaultdict(<type 'list'>, {0: [{'usage': [212992, 106496, 147456, 196608, 196608, 131072, 524288, 2621440, 5242880, 6291456, 423624704], 'nr_free': [52, 13, 9, 6, 3, 1, 2, 5, 5, 3, 101], 'zone': 'DMA', 'sz_fragment': [4096, 8192, 16384, 32768, 65536, 131072, 262144, 524288, 1048576, 2097152, 4194304]}]})
Node: 0
Zone: DMA
Free KiB in zone: 429000.00
       Fragment size        Free fragments       Total available KiB
       4096                 52                   208.0
       8192                 13                   104.0
       16384                9                    144.0
       32768                6                    192.0
       65536                3                    192.0
       131072               1                    128.0
       262144               2                    512.0
       524288               5                    2560.0
       1048576              5                    5120.0
       2097152              3                    6144.0
       4194304              101                  413696.0
and now some hours later after I activate zram compression and port swapness from standard 60 to 1.
2016-05-28 16:55:37,433 - main - INFO - Starting....
2016-05-28 16:55:37,433 - main - INFO - Parsed options: {'size': None}
<logging.Logger object at 0x7fb41324d0>
2016-05-28 16:55:37,436 - main - DEBUG - Parsing line: Node 0, zone      DMA    888   1094    404    169     57     22     13      3      0      1      1
2016-05-28 16:55:37,439 - main - DEBUG - Parsed line: {'numa_node': '0', 'zone': 'DMA', 'nr_free': '888   1094    404    169     57     22     13      3      0      1      1'}
2016-05-28 16:55:37,440 - main - INFO - defaultdict(<type 'list'>, {0: [{'usage': [3637248, 8962048, 6619136, 5537792, 3735552, 2883584, 3407872, 1572864, 0, 2097152, 4194304], 'nr_free': [888, 1094, 404, 169, 57, 22, 13, 3, 0, 1, 1], 'zone': 'DMA', 'sz_fragment': [4096, 8192, 16384, 32768, 65536, 131072, 262144, 524288, 1048576, 2097152, 4194304]}]})
Node: 0
Zone: DMA
Free KiB in zone: 41648.00
       4096                 888                  3552.0
       8192                 1094                 8752.0
       16384                404                  6464.0
       32768                169                  5408.0
       65536                57                   3648.0
       131072               22                   2816.0
       262144               13                   3328.0
       524288               3                    1536.0
       1048576              0                    0.0
       2097152              1                    2048.0
       4194304              1                    4096.0
never get a problem until now.
  Debian installer on Pine A64+ but no hdmi mrwick 1 4,953 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 12,931 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 2,987 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 10,247 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 122,505 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 4,819 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 4,263 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 6,365 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 13,262 03-29-2019, 02:00 AM
Last Post: desai_amogh
  (ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release lenny.raposo-pine64.pro 259 466,640 05-21-2018, 06:30 AM
Last Post: Luke
