Debian installer on Pine A64+ but no hdmi
The reason I purchased the Pine A64+ was to be able to go through the Debian install process, choosing a minimum of packages and starting with a configuration that only I would understand :-D This is my usual method of operation for about 20 years.
After following the steps on the debian wiki and running into no kernel modules found issues, I ended up downloading directly from:
http://ftp.debian.org/debian/dists/stabl...rd-images/
doing the zcat > to the card and was able to do a fairly regular debian install process.
Strange thing is, it is always over the console with the olimex USB-Serial cable:
https://www.olimex.com/Products/Componen...l-Cable-F/
OK, no problem for an install, but then going to testing, kernel 5.6.0-1-arm64 and still no HDMI, even console. Serial is nice, and ssh is most likely the main way I will be interfacing with the computer, but I am curious as to how to troubleshoot the HDMI output.
Still searching but maybe someone here can already point me in the right direction
for me, HDMI is working perfectly fine (as console output) on a A64 with 2GB (I assume it's the plus model?) and the current unstable kernel (5.7). I guess the reason why it may not be working for you could be an outdated u-boot.
I installed my OS in a VM first (using the official installer) and then moved it over to the real hardware. You can read about how I did that here:
https://www.kulesz.me/post/140-debian-de...4-install/
Hope this helps.
Information Howto: OctoPrint Working on Pine 64 chaos_actual125 22 68,555 07-11-2021, 04:13 AM
Last Post: zer0sig
  Debian Pine64 h264/5 Video under vlc ozcy 6 19,616 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 5,216 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 16,106 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 162,012 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 8,039 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 7,388 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 10,498 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 20,244 03-29-2019, 02:00 AM
Last Post: desai_amogh
  Jdownloader or similar installer saviod 4 11,187 09-01-2018, 12:25 AM
Last Post: M00NBEAM_pt
