My Daily QA - 2020-09-01
Be aware, these tests are being executed using an out-of-box testing methodology. All tests are preformed with minimal interaction/setup of devices outside of: OS imaging/updating,  SIM installation, Wifi Configuration,  and Power Cycling the devices.
Resultsubports/2020-09-01-TMobile
Conclusion: This OS is not ready for the pinephone to become a daily driver.
Notes: Needed to restart phone to get audio after failed 4G test. Submitted an issue. Outbound 3G SMS broken, submitted a ticket. Needed to restart camera app to test. Initial load rendering was completely incorrect. (SPlit the image in half and put the bottom half on the top.) Also I did not test Verizon because results not likely to change. Instead I might begin testing PMOS since I just got my PMOS device today,
Issues:
Failed outbound 4G calls kills call audio.
Unable to send 3G SMS Since Dev-158
4G outbound calls broken.
Phone gets stuck in a weird lock state when spamming power button.
Just curious about your Verizon sim card, is that directly from Verizon, or through a reseller ?
I tried Verizon sim cards from TracFone and from Net 10 and my new PMOS phones all say 'No sim card' ?
(09-28-2020, 10:26 PM)bcnaz Wrote: Just curious about your Verizon sim card,  is that directly from Verizon,  or through a reseller ?
I went into verizon and asked to set one up. They do need to attempt an IMEI though to activate it. But I convinced the guy to use a number from a junker they had in the back.
With that in mind, if you have an old phone sitting around...
  Ordered my 3 phones on April 20, 2020 and only 1 arrived! bndoug66 9 9,066 10-09-2020, 05:56 PM
Last Post: bndoug66
  My Daily QA - 2020-10-01 plainenough 1 2,953 10-02-2020, 09:56 PM
Last Post: Phillip Bell
  My Daily QA - 2020-09-30 plainenough 0 1,931 09-30-2020, 01:48 PM
Last Post: plainenough
  My Daily QA - 2020-09-28 plainenough 3 5,050 09-29-2020, 10:51 AM
Last Post: LinAdmin2
  My Daily QA - 2020-09-29 plainenough 0 1,914 09-29-2020, 08:32 AM
  My Daily QA - 2020-09-10 plainenough 13 16,092 09-20-2020, 05:07 AM
Last Post: firefox-58
  My Daily QA - 2020-09-09 plainenough 1 2,764 09-09-2020, 11:37 PM
Last Post: bcnaz
  My Daily QA - 2020-09-08 plainenough 0 1,971 09-08-2020, 03:58 PM
  My Daily QA - 2020-09-03 plainenough 0 1,989 09-03-2020, 12:09 PM
  My Daily QA - 2020-09-02 plainenough 8 9,575 09-03-2020, 11:53 AM
