How to add an external power button?
Does the RockPro64 have header pins (or something similar) for an external power button? I would like to add such a button, since the on-board one can be difficult to use.
I see four holes at the corner of the board near the headphone jack. They're at the bottom right of this close-up view. One of those contacts is labeled PWR. Does that mean it's for delivering power, or will grounding it act like pressing the power switch? (The other contacts are labeled GND, REC, GND.)
If those holes are the contacts I need, what size header will fit them?
Is there a better way to do this?
(08-15-2020, 03:06 AM)foresto Wrote: Does the RockPro64 have header pins (or something similar) for an external power button? I would like to add such a button, since the on-board one can be difficult to use.
Have you thought about simply unsoldering the current one and either replacing it with another, or wiring it to a new location?
Another option is to bypass the power switch and but something like this to have an more external switch https://m.aliexpress.com/item/32942058069.html ?
Look @ sheet 6 from 33 http://files.pine64.org/doc/rockpro64/ro...21-SCH.pdf
The four holes are power and reset. I use these Buttons for my NAS.
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
(08-15-2020, 05:36 AM)Bullet64 Wrote: Look @ sheet 6 from 33 http://files.pine64.org/doc/rockpro64/ro...21-SCH.pdf
CON16 on schematic page 6 looks promising. How do you know where it is on the board? Many board components are unlabeled, and I don't see a "CON16" label anywhere. Those four holes have labels, but one says "REC", which doesn't match anything on schematic page 6.
(08-15-2020, 03:37 AM)SpoofyKid Wrote: Have you thought about simply unsoldering the current one and either replacing it with another, or wiring it to a new location?
The thought crossed my mind, but I would prefer to avoid it if possible, especially while the warranty is still good.
(08-15-2020, 03:37 AM)SpoofyKid Wrote: Another option is to bypass the power switch and but something like this to have an more external switch https://m.aliexpress.com/item/32942058069.html ?
That's a neat find, but I want a button that will tell my OS to do a clean shutdown, like the on-board button does.
I used a multimeter to confirm that the innermost corner hole is connected to the on-board power button, and its neighbors to ground. I then soldered in a 2-pin header (2.54mm pitch) and used a matching jumper to attach a pushbutton switch. The NAS case has a hole for an IR receiver, but since I don't use one of those, I used the hole for the switch. M5 threads fit through the hole nicely.
Now I have an easy-to-see, easy-to-press, software-controlled, red power button. Mission accomplished. Smile
(09-08-2020, 01:57 PM)foresto Wrote: I used a multimeter to confirm that the innermost corner hole is connected to the on-board power button, and its neighbors to ground. I then soldered in a 2-pin header (2.54mm pitch) and used a matching jumper to attach a pushbutton switch. The NAS case has a hole for an IR receiver, but since I don't use one of those, I used the hole for a panel-mount switch. The M5 threads fit through the hole nicely.
Would you have a picture for future reference is anyone wants to duplicate this?
(09-08-2020, 02:04 PM)SpoofyKid Wrote: Would you have a picture for future reference is anyone wants to duplicate this?
Several. I posted a thread about it.
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,083 04-01-2024, 10:24 PM
Last Post: nano2
  RP64 Won't Boot After Power Down ColPanic_ 10 7,848 06-27-2023, 07:31 AM
Last Post: dkebler
  External Touchscreen via DP-Alt Mode soloquintett 0 789 05-01-2023, 12:29 PM
Last Post: soloquintett
  NAS Setup: Hdds PSU external power option Robotik 1 1,736 07-18-2022, 10:10 PM
Last Post: zer0sig
  NAS case HDD power cable failure (buck failure) ashleymills 1 1,920 04-01-2022, 11:25 AM
Last Post: ashleymills
  Power In Via DC Out actionhank 0 1,308 01-28-2022, 09:45 AM
Last Post: actionhank
  NAS mods: external serial port and power button foresto 4 6,575 10-04-2020, 11:21 PM
Last Post: zer0sig
  Power Supply - Barrel length Wiing 2 3,623 09-20-2020, 12:38 AM
Last Post: Wiing
  12V 3A power supply and NVMe - PCIe kaylios 3 4,985 08-25-2019, 03:31 AM
Last Post: kaylios
  Sata power cable sputnik13 1 2,955 08-15-2019, 06:32 PM
