Xwayland on Phosh works?
I have tried to install several applications that I know doesn't work on wayland, but i was hopping they could work with xwayland on phosh but i dont know if even phosh has xwayland implemented or something else have to be installed.
So far no luck running those applications.
Can someone give some light about this?
Regads!
Xwayland is running for me, and applications that so far as I know don't claim Wayland support are running (foxtrotgps, navit). I don't know if it was always present, or was pulled in as a dependency by something else - so far as I remember i didn't do anything beyond installing things to make it work. The default window sizes for each were wrong for a phone, and there's no easy way I've found to resize the windows. Both applications have mechanisms to run them fullscreen (config file for navit, command line switch for foxtrotgps) and they run well that way, but other applications may have a problem with that.
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,676 01-15-2025, 08:08 PM
  Auto start application on Phosh login Zebulon Walton 8 13,482 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  opensnitch outbound firewall now works on mobian vusra 2 4,763 07-09-2023, 01:37 AM
Last Post: vusra
  Using sway along phosh fdlamotte 2 6,445 05-11-2023, 04:24 PM
Last Post: kabouik
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 5,458 02-24-2023, 12:11 AM
Last Post: nexion
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 26,528 10-14-2022, 05:38 PM
Last Post: Krafter
Exclamation Impossible to minimize a window with Phosh anonymous 7 10,452 08-18-2022, 01:53 PM
Last Post: dante404
  Phosh 0.20 beta on mobian Anthony1224 1 3,968 06-11-2022, 06:29 AM
  Transparent Phosh App Grid? arno_nuehm 1 3,753 03-15-2022, 06:00 AM
Last Post: dante404
  Phosh modem on/off effectiveness? Zebulon Walton 0 2,452 01-24-2022, 09:21 AM
