Earpiece emits static
For reference, I am using a Braveheart with Mobian
Does anyone else suffer from the earpiece emitting static (at full volume?)
Curious if this is caused by the hardware, software, or potential water ingress.
Mine don't produce any static at full volume, while not playing. It does not make any difference if the PP is charging or not. Braveheart CE . Mobian updated.
It could be I am getting deaf. : )
(07-24-2020, 01:13 AM)fernando_c_m Wrote: Braveheart  CE
Which is it? Wink
Thanks either way. Last night I saw a wishlist item for Mobian: 'Fix hiss/whine noise present whenever audio hardware is activated'
So it's probably related to that. The static seemingly doesn't emit all of the time.
(07-24-2020, 08:29 AM)jed Wrote: Which is it
Yes, I mixed up the two versions. : )
hw revision 1.2 "community edition"
I heard the hissing sound while making calls on UBPorts. It was only when the audio was started.
But it happened at every audio level.
Understood, I experience something similar.
I'll mark the topic as Solved, as this issue doesn't appear to be as destructive as first thought.
Thanks for your help @fernando_c_m  Cool
  Lost internal earpiece Veraendert 3 2,377 02-14-2022, 07:51 AM
Last Post: Veraendert
  PWM whine near earpiece in low signal phone call and loud sound sent to the other end vortex 29 26,395 01-14-2022, 11:00 AM
Last Post: eugenr
  inner earpiece speaker replacement dcinoz 4 4,428 07-24-2021, 04:37 AM
Last Post: dcinoz
